This is the OctaneRender_Studio+_2026_3_for_3dsmax_v26.9 version, without rendering details, polygons, or algorithm processing in the viewport.
Thanks OR team.
OctaneRender® 2026.4 for 3ds max® v26.10
- Pelana001_1
- Contact:
- paride4331
Hi Pelana001_1,
I think it's just a matter of perspective and lighting.
- Pelana001_1
- Contact:
HI paride4331, thanks for answer, very kind, I'll using the version OctaneRender® 2026.3 for 3ds max® v26.9 and I don't have issues.
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
Hi neonZorglub,
Do you know why slaves crash when vram usage is over their vram limit instead of using out of core RAM?
- paride4331
Hi coilbook,coilbook wrote: Wed Jul 29, 2026 1:20 amHi neonZorglub,
Did you set the Out-of-Core setting on the node during its setup?
- Elvissuperstar007
- Contact:
The orthographic camera is broken.
- Bug The orthographic camera.rar
- (19.08 MiB) Downloaded 58 times
- Elvissuperstar007
- Contact:
The bug does exist after all; it doesn't happen every time, but it shows up in 70% of cases.
- paride4331
Hi Elvissuperstar007,
Thanks. I've submitted my report to the developers. As a temporary workaround, switch to a different 3ds Max viewport and then switch back to the Octane Camera viewport. This causes the render to resume progressing. However, if the Ortho option is turned off and then back on, the issue reappears, and you'll need to repeat the same workaround.
Hi Paride, yes I did. 16 gb per slave. Not sure if maybe all mesh cannot fit vram maybe. Most textures are procedural. Thank you.paride4331 wrote: Wed Jul 29, 2026 1:31 pmHi coilbook,coilbook wrote: Wed Jul 29, 2026 1:20 amHi neonZorglub,
- paride4331
Hi coilbook,
16 GB o-o-c limit could be the bottleneck. If the scene exceeds the available VRAM by more than those 16 GB, Octane may still run out of memory and crash instead of using more system RAM. Also, some data may still need to fit in VRAM, so large or complex meshes, displacement, subdivision, volumes, hair, etc. could be the actual cause. Since most textures are procedural, I’d look at the geometry and check the VRAM/o-o-c usage in the Octane log right before the crash.
