Languaje in chinese.
Pelana001_1
Good evening, why does the Render Settings option change from English to Chinese when switching from Direct to Pathtracing?
In other words, Render Settings appears in Direct, but in Pathtracing it appears in a different language.
Thanks, OR team.
Add image like reference.
Languaje un chinese
Languaje un chinese
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
paride4331
Hi Pelana001_1,
Never seen anything like this. Did you happen to install some kind of Chinese localized plugin for 3ds Max? Any chance did you install the Chinese localized version of Octane SA?
Pelana001_1
Hello Parid, I haven't installed any Chinese programs or plugins; what I did was install the latest version of OR for 3ds Max, the version downloaded directly from Otoy's website.
The version is OctaneRender_Studio+_2026_2_for_3dsmax_v26.7, and the standalone version is OctaneRender_Studio+_2026_3_win.
Thanks you for responde me.
paride4331
Hi Pelana001_1,
I ran a few tests, but I wasn’t able to reproduce the issue. Did you perhaps load a specific scene, maybe even one with materials or assets from another render engine that were then converted to Octane? I’ll forward my own report to the developers. As far as I know, I’m not aware of any similar issues on my side.
paride4331
Hi Pelana001_1,
It’s a minor issue that occurs with a specific sequence of commands. It doesn’t cause any functional problems, and the workaround is simply to close and reopen the Render Setup window.
Pelana001_1
Hi paride4331, thank you for response. very Kind.
Return to “Autodesk 3Ds Max”
