Octane 2026.3 for Cinema4D - v1.9.1
ChrisHekman
mingmingAS wrote: Wed May 20, 2026 2:25 am The independent graphics node will crash
I found the crash and it will be part of the hotfix build
19Nik90
bepeg4d wrote: Wed May 20, 2026 8:07 am
19Nik90 wrote: Wed May 20, 2026 6:22 am Hello,
Just updated to this version V1.9.1, but the error that I've reported on the previous version is still present:
"Inside the Octane Camera Tag, every time I try to enable the Imager, Cinema 4D crashes."
Thank you
Nik
Hi Nik,
Could you share a screen capture video of the steps before the crash, thanks?
ciao,
Beppe
Ciao Beppe,
Problem solved, it's something about the C4D interface, using a standard C4D layout the problem doesn't occur.
Thank you
Nik
Tim0042
One small bug I just came across: The depth dropdown in the Render AOV Manager starts off as 16 Bit in a clean new scene, but once you change it to 32, it shows as blank and can't be changed to either 16 or 32, it stays empty.
Tim0042
Ah, but the Material Link node is amazing - looks extremely useful, thx! Just this morning I was looking for a way to blend between two existing comp materials without having to resort to the old mix material or copying a large amount of nodes.
Only downside I've noticed so far is that the LV doesn't automatically update when I'm changing something in one of the linked materials, it only reacts to changes in the master mat. Is this simply a limitation? : )
19Nik90 wrote: Wed May 20, 2026 12:54 pm
Thank you
Nik
Hi Nik,
ciao,
Beppe
Ciao Beppe,
Thank you
Nik
Thanks Nik!
Could you share with me via PM the specific layout that was crashing?
ciao,
Beppe
ChrisHekman
Tim0042 wrote: Wed May 20, 2026 2:54 pm Only downside I've noticed so far is that the LV doesn't automatically update when I'm changing something in one of the linked materials, it only reacts to changes in the master mat. Is this simply a limitation? : )
This was an oversight. I'll see if we can fix this.
Edovech87
I've a problem to change kernel on my personal cinema4d interface. If i change kernel from DL to path tracing, there's a crash of cinema4d. Do i need to rebuild my interface?
DinoMuhic
Edovech87 wrote: Wed May 20, 2026 7:29 pm I've a problem to change kernel on my personal cinema4d interface. If i change kernel from DL to path tracing, there's a crash of cinema4d. Do i need to rebuild my interface?
can you send us your c4d layout file? but yes, rebuilding after a version bump is always advised. at least remove all octane related windows, close them, then open new ones and add them back into your layout
Edovech87
I tried a new standard interface but cinema4d crash on kernel change, always. Now i'm back on v1.9.0
Tim0042
ChrisHekman wrote: Wed May 20, 2026 3:40 pm This was an oversight. I'll see if we can fix this.
Aah, perfect, thank you! : )
One more thing I noticed when rendering an existing scene from 1.9.0 in 1.9.1: Some node heavy materials change their look a bit. I think it might be connected to usage of the Gradient Node and you do list this node under the "improved color conversion" section. Could this be possible, even for just a grayscale gradient? I will try to make some tests with a simpler material.
Return to “Releases”
