Octane 2026.3 for Cinema4D - v1.9.1
ChrisHekman
Hi all,
This is a plugin release for OctaneRender 2026.3.
The main changes in this build are the new Material Link node, Octane 2026.3 and splitting the Octane settings between Scene Settings and Plugin Settings.
The split was done because certain settings were not stored in the scene but did change how the scene looks and is rendered. This could cause different results on different machines.
Note:
Downgrading from this version and previous version (1.9.0 / 1.8.5) to an older version (1.8.4 and lower) of the plugin is likely to break the colorspace on texture image nodes.
You can use this python script to fix the issue after downgrading.
download/file.php?id=96735
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.3 - 1.9.1 plugin revisions
  • Updated to Octane 2026.3
  • Added a Material Link node for cleaner material linking. Can be used on Composite and Mix materials
  • Added support for Cinema 4D OCIO settings in Cinema 4D 2026
  • Live viewer can now we resized much smaller
  • Split Octane Plugin Settings into:
    • Plugin Settings – Global plugin-wide settings shared across all scenes
    • Scene Settings – Stored per scene within the Cinema 4D file
  • Color and Float attributes now support values up to 10 instead of 2
  • Added a Node Editor button to Null Materials
  • HDR textures now import with the correct color space
  • Disabled unnecessary node previews
  • Attribute strings are now preserved when switching Attribute nodes from Float to Color
  • Improved Shift/Ctrl selection behavior in the Node Editor
  • Added Vector4 input support for OSL Shader nodes
  • Added a Clear/Delete button to the Rest Position Tag
  • Material Layers and Rounded Edges pins are now enabled by default
  • Typed-in values are now preserved in the Adjust Contrast (SDR Only) AOV
  • Fixed the Select Sub Nodes command in the Node Editor View menu
  • Fixed various minor OSL loading issues
  • Plugin now handles activation failures more gracefully
  • Added a Clamp pin to the Displacement node
  • Added I/O type information to Baking Texture and Image Tile nodes
  • Added additional Chinese translations
  • Fixed a performance regression affecting Cloners
  • Bug reports are now checked before logs are cleared
  • Aligned logging checkboxes for improved UI consistency
  • Fixed adding Render AOV layer parameters for Texture AOVs
  • Improved color conversion for:
    • XNoise
    • XColor
    • XGradient
    • XColorizer
    • Gradient nodes
    • Octane Volume Ramp
    • Tex Composite
    • AOV Light Mixer nodes
    • AOV Adjust White Balance
    • ToonRamp
Downloads:
WINDOWS STUDIO+ 2026.3 - 1.9.1 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.3 - 1.9.1 (R21-R2026)
Archive
WINDOWS DEMO 2026.3- 1.9.1 (R21-R2026)
Installer
Archive
2026.3 - Nodes
OctaneRender Studio+ 2026.3 Node for Windows (installer)
OctaneRender Studio+ 2026.3 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.3 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2- Check GPU frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use the same value. Also try to optimize your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for investigating and bring a fix or solution.
Thanks for helping the development by your feedbacks! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by the firewall and any antivirus software.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
First, remove all octane related stuff from plugins and the main folder of Cinema4D.
Also, download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Kalua
Thank you, Chris!
Octane User since V1 Beta
mingmingAS
The independent graphics node will crash
nycjunglist
I can also confirm that a C4D crash occurs while enabling Solo Mode on a material node.
I came across some startup issues with older versions of C4D while investigating a separate Octane-related crash. During startup, there's a resource error with the following versions and files located in <C4D version>/resource/modules/c4dplugin/description/:
  • R24 (24.111): dmodeling.res, line 109; obaselist.res, line 22
  • R26 (26.107): dmodeling.res, line 111; obaselist.res, line 23
  • 2023.2.2: dmodeling.res, line 104; obaselist.res, line 23
Clicking 'OK' or the close window X just cycles through the error windows, and C4D needs to be force quit from the Task Manager to close. I've isolated the issue to Octane by removing the folder from the plugin directory, and I've also renamed the preferences folder to force C4D to create a default just in case the problem was layout-related.
Ryzen 9 5950x | 128 GB RAM | 5090 + 3080Ti
19Nik90
Hello,
Just updated to this version V1.9.1, but the error that I've reported on the previous version is still present:
"Inside the Octane Camera Tag, every time I try to enable the Imager, Cinema 4D crashes."
Thank you
Nik
David_S
Hi there,
unzip the OSX-Archive doesn't work.
mingmingAS wrote: Wed May 20, 2026 2:25 am The independent graphics node will crash
Sorry but I cannot reproduce the issue with Solo mode, it seems to work ok in both macOS and PC versions here:
ciao,
Beppe
19Nik90 wrote: Wed May 20, 2026 6:22 am Hello,
Thank you
Nik
Hi Nik,
Could you share a screen capture video of the steps before the crash, thanks?
ciao,
Beppe
David_S wrote: Wed May 20, 2026 6:39 am Hi there,
Unzipping macOS version works ok here in macOS Tahoe 26.4,.1 and 26.5!
Could you share more info on your macOS system?
ciao,
Beppe
ChrisHekman
nycjunglist wrote: Wed May 20, 2026 5:37 am I can also confirm that a C4D crash occurs while enabling Solo Mode on a material node.
We will be releasing a hotfix soon.
For now the workaround is just to hold enter until the popups stop and you can continue.
Return to “Releases”
