rendering bug
remKa
Hello,
I have a new bug since the last release (I didn't change my drivers), the rendering of a sequence stops at a certain frame, I can cancel or pause the render but I can't do anything else, I have to hard quit 3ds Max.
When I relaunch 3ds Max, I have an error telling me that I have no active GPU, please see the screenshot and the Octane log.
I have to restart my computer to make it work again.
It happens on old and new scenes, sometimes after hours of renderings, sometime after 20 min
octane 2026.2 260324 143639.txt
(404 Bytes) Downloaded 66 times
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
paride4331
Hi remKa,
Was out-of-core turned on or off?
remKa
Default setting, ON I guess, should I turn it off ?
What's odd is that it's happening since the last release
paride4331
Hi remKa,
out-of-core on is ok. Did you notice if the driver crashes happen much later in lighter scenes and earlier in really heavy ones?
remKa
Not really, that's pretty random
paride4331
Hi remKa,
Could you run these two lines in PowerShell as an administrator, then restart Windows and run a test?
reg add "HKLM\SYSTEM\CurrentControlSet\Control\GraphicsDrivers" /v TdrDelay /t REG_DWORD /d 60 /f
reg add "HKLM\SYSTEM\CurrentControlSet\Control\GraphicsDrivers" /v TdrDdiDelay /t REG_DWORD /d 60 /f
Elvissuperstar007
Try installing this driver:
581.57-desktop-win10-win11-64bit-international-dch-whql
Since all 590.00+ drivers are very buggy.
Return to “Autodesk 3Ds Max”
