OctaneRender® 2026.2 for 3ds max® v26.5
neonZorglub
coilbook wrote: Tue Feb 24, 2026 1:19 am Hi neonZorglub,
Can you look into tyflow and slow eval times? Over 100,000 ty instanced little particles as low res spheres and eval times are 2-3 min per frame. But they are supposed to be instances.
Thank you
Hi coilbook,
Sure, I'll have a look.
Could you share a sample scene ?
That would help to check the settings you use.
coilbook
neonZorglub wrote: Tue Feb 24, 2026 2:49 am
Thank you
Hi coilbook,
I will. Can you please add AI tiling system where a seamless map from far away wont get any patterns or RGB gets converted to procedural texture.
coilbook
Thank you
Hi coilbook,
Hi neonZorglub,
1. Here is the scene for slow eval times with tyflow. When you open it just try to render fram 190-250 It gets very slow. (I think Render instances in tyflow mesh even is not working. It renders as copies using a lot of vram)
Someone had the same problem with tyflow viewtopic.php?t=73516&start=10
2. Anyway to get Sparkles shader like in fstorm? You have flakes shader already but it doesn't sparkle as good as fstorm sparkles shader. Theirs is just glowing sparkles and they are very tiny.
Here is the video of theirs https://youtu.be/M8G0Pk4oxwk?si=ENW7qq8ca70g0Kfe
Thank you
tyflow slow eval.zip
(3.62 MiB) Downloaded 5 times
Elvissuperstar007
I’ll have to write the post again. This build is better than the previous one — that one was constantly crashing. This one crashes after some time if I right-click in 3ds Max and open the Octane Render viewport. It has crashed 8 times since this morning. This has never happened before.
neonZorglub
Elvissuperstar007 wrote: Tue Feb 24, 2026 8:45 pm I’ll have to write the post again. This build is better than the previous one — that one was constantly crashing. This one crashes after some time if I right-click in 3ds Max and open the Octane Render viewport. It has crashed 8 times since this morning. This has never happened before.
Hi Elvissuperstar007,
Sorry for the late reply.
I tested a few large scenes, but couldn't reproduce this issue when opening the Octane viewport.
It's very hard to investigate such crashes without much information..
The best for us would be to test with your full scene. (saving with Archive to a zip file)
Could you send me your current scene by PM (we don't share users data of course)
Thank you
neonZorglub
coilbook wrote: Tue Feb 24, 2026 7:54 pm Hi neonZorglub,
Thank you
Hi coilbook,
Thank you for your scene!
I checked at different frames (0,50,100,200) and with different settings (no tyFlow, mesh vs instances, no motion blur, no emission on sparks)
I also checked a basic scene with 100k, 500k, 1M, 2M particles
Here are some results:
-The evaluation time is basically negligible (~5.5%, 6 sec maxi for a 108 sec render)
(the evaluation time is where we get the particle data from tyFlow and send it to the Octane engine)
This goes down to 0.3 % (0.3 sec) on a 80 sec render with no emission and no motion blur
-Render time without tyFlow (all tyFlow objects hidden, 79.05 sec) is basically the same as with tyflow objects with no emission and no motion blur (80.78 sec)
-The main performance hit comes from having around 200000 particles acting as lights (because of the emission texture), and the motion blur also adding a big hit, acting as doubling the geometry.
Of course, for a nice sparkle effect like in your scene, you need both emission and motion blur, so there's not much we can do about particles.
-The render time would be similar if you had instances of spheres manually created instead of using tyFlow..
-To reduce render time, you could try to change some parameters of the emission texture (sampling rate, distribution, ...).
Also of course, reduce the kernel Sample per pixel, and use the denoiser instead...
Various other settings also influence the render time, but that's a more general topic..
-I noted once a potential bug when disabling motion blur and re-enabling it, the render time jumped to 168 sec instead of 108.. a re-load of the scene could fix it.
I'll keep investigating. but I think that's not related to your issue, unless you also turn on and off the motion blur while working..
I hope that helps,
I'll have a look at the sparkles shader.
HHbomb
For ME this version is more stable than 2026.1. 2026.1 constently crashing when using high displacement mode. Now is far more stable. BUT evaluation time is very very ( very ) slow.( Even without displacement). Do Octane evaluate even non visible objects ?
Return to “Releases”
