Standalone 2025.4 ( I have to run this version as anything higher will not launch since the launching method changed heading to 2026)
I have loaded a few very large abc files. 7-21GB
Both do not render the abc all the way. As I scroll though the timeline it will be blank unless I make a big enough time jump. e.g at 10 frames it is loaded if I go to 13 it will not load. If I go to 30 it will.
When I render out the batch some will render with no abc except where I went to that particular time frame to view it. e.g if I went to 30 and it loaded before I batch then it will render but 34 etc will not.
It is like the abc is not cache-ing before rendering each frame.
Looked in the preferences for import abc and did not see a feature to "load before render" etc.
Am I missing something?
Peter
ABC Files not fully loading when batch rendering
Hi Peter,
Weird!
Please write to help at otoy dot com so we can investigate more deeply this specific case, thanks.
ciao,
Beppe
Weird!
ciao,
Beppe
- p3taotoy
- Contact:
Will do Beppe
I hate to admit it but I think it may be a case of "time for a fresh install of windows Peter!" Too many little things that do not usually happen with octane for it to be an octane thing.
I am just putting it off cause I can get done what I need most of the time :>)) and I hate rebuilding a fully put together system :>))
Have a good one mate
Peter
Peter
I'm with you Peter!
See you soon, and have a good one you too mate!
ciao,
Beppe
ciao,
Beppe
