Blender 5.0.1 with 31.2 Beta
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
dinosgr
Oh , you could just use c:\Users\..... user name\AppData\Roaming\Blender Foundation\Blender\5.0\scripts\startup\bl_app_templates_user\
were you copy the templates you need and blender will catch them.
inside there needs 2 directories for each of your templates : OctaneRender and Octane Render Compositor & Denoiser (those 2 should be directories)
and each inside needs a preferences file that's loading the Octane Add-on and your 2 seperate blend file OctaneRender startup (default) and Octane Render startup (Compositor & Denoiser), (each to their respective directory).
Importand now the files inside the directories should be blender's default naming scheme , not using you custom names : that is (startup.blend , and userprefs.blend)
/wave
linograndiotoy
From the developer:
"It's a Blender crash and I've used a trick to fix it. Basically, calling wm.read_homefile directly from a menu-invoked operator can crash Blender in some templates (e.g. VFX), due to UI post-processing accessing invalid RNA pointers."
I've tested the new addon version implementing the change and it works great.
You can download it:
octane_blender_addon-31.2-beta(6).zip
(12.99 MiB) Downloaded 98 times
It will be part of the next official update.
dinosgr
Thank you Lino
/best
linograndiotoy
Sure!
Does it work now?
dinosgr
It works for sure fine with most templates xcept some atribute errors when you switch to sculpting from octane templates, and some rna errors.
I was trying to understand if it was some blender overseen bug , so I tried renderman that never gave any errors switching to its own template to any blender, or any custom made .
At the end you will nail it, no rush as I bet you have more importand things to do, just add it to do list.
Thanks for looking into it!
01:02.610 bpy.rna | WARNING current value '-1' matches no enum in 'SpaceNodeEditor', '(null)', 'tree_type'
OctaneBlender.init: opts = {'server': None, 'port': None, 'cert': None}
01:02.641 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneKernelOutputNode'
01:02.641 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneRenderAOVOutputNode'
01:02.641 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneOutputAOVGroupOutputNode'
01:02.641 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneEditorWorldOutputNode'
01:02.656 bpy.rna | WARNING unable to get Python class for RNA struct 'octane_composite_nodes'
01:02.656 bpy.rna | WARNING unable to get Python class for RNA struct 'octane_kernel_nodes'
01:02.656 bpy.rna | WARNING unable to get Python class for RNA struct 'octane_render_aov_nodes'
01:02.703 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneDaylightEnvironment'
01:02.735 bpy.rna | WARNING unable to get Python class for RNA struct 'OctanePathTracingKernel'
01:02.766 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneToonMaterial'
01:02.766 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneUniversalMaterial'
01:02.860 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneOutputAOVsOutputAOVGroup'
01:02.860 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneBlendingSettings'
01:02.860 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneOutputAOVsRenderAOV'
01:02.860 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneOutputAOVsOutputAOV'
01:02.860 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneOutputAOVsOpenImageDenoise'
01:02.891 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneRenderAOVGroup'
01:02.938 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneMultiplyTexture'
01:02.938 bpy.rna | WARNING unable to get Python class for RNA struct 'OctanePolygonSide'
01:02.953 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneRaySwitch'
01:03.000 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneSunDirection'
01:03.000 bpy.rna | WARNING unable to get Python class for RNA struct 'OctaneLightIDBitValue'
And when go to Sculpting:
Traceback (most recent call last):
File "C:\Users\dinos\AppData\Roaming\Blender Foundation\Blender\5.0\scripts\addons\octane\uis\viewport_header.py", line 174, in OCTANE_VIEW3D_HT_header_draw
is_paint_tool = brush.sculpt_tool in {'PAINT', 'SMEAR'}
AttributeError: 'Brush' object has no attribute 'sculpt_tool'
00:38.250 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:38.485 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:38.594 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:38.703 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:38.797 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:38.906 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:38.953 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:39.000 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:39.094 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:39.188 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.016 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.063 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.094 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.235 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.344 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.469 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.500 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.563 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
00:42.703 bpy.rna | ERROR Python script error in VIEW3D_HT_header.draw
For sure its better with the other templates.
Return to “Bug Reports”
