Analytic Lights & Post Processing crashing Octane Server
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
pegot
Big issue with Analytic lights causing some kind of memory error under certain situations. This is happening in Windows version of OctaneBlender and reproduced on two different computers.
I am using an Analytic light set to disc. Octane Server crashes while using Analytic lights with post processing in viewport preview render. The first initiation of viewport render sometimes works fine - one can see the post process effects on the Analytic lights, adjust settings, and freely move around during viewport rendering. However, if one shuts down rendered view by going back into shaded view and after that again attempts a viewport render - server crashes with following error: "ERROR! check console for detailed error message."
Various Errors from Console logs on numerous separate crashes while testing show this:
Octane: ERROR. Server log:
Failed devices:
NVIDIA GeForce RTX 5090(device 0), error message: "CUDA error (700) on device 0: an illegal memory access was encountered -> failed to allocate device memory"
Last Octane engine log entries:
CUDA error (700) on device 1: an illegal memory access was encountered
-> failed to load symbol data to the device(const24)
device 1: failed to upload light parameters for post.
Failed devices:
NVIDIA GeForce RTX 5090(device 0), error message: "CUDA error (700) on device 0: an illegal memory access was encountered -> could not get memory info"
OptiX error for device 1: [ERROR] Failed to copy internal launch buffer (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
Error recording resource event on user stream (CUDA error string: an illegal memory access was encountered, CUDA error code: 700)
OptiX API error for device 1: CUDA error
device 1: RTX tracing for post failed
device 0: failed to allocate post-fx buffer
-> failed to deallocate device memory
Failed devices:
Strange thing is this issue only happens in viewport render. It doesn’t happen at all in camera render view or final render as long as viewport render hasn't been initiated (or sometimes if it was only initiated once).
The error doesn’t occur on Mac. And I have only tried this with the current stable standard plugin not the add on beta. OctaneBlender version is 2025.3 - 30.7 [STABLE].
Can provide more detailed logs and specs of computers if necessary. Basically, I'm on Windows 10 using a 5090 and a 3090 on main machine and a 3080, 3080 Ti, and a 1080 Ti on the other.
NVIDIA Studio driver 581.29. Just updated to Studio driver 581.57 and issue persists (perhaps even more unstable).
The Mac, which tested fine, is a Mac Mini M1 running Sequoia 15.7.1.
Will post this in Discord channel as well.
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
linograndiotoy
As you found out, the problem happens only on systems using multiple GPUs. It would be nice to try the same using the addon version and verify if the issue also happens there.
pegot
Just tested with addon version and issue doesn't appear to be present there.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Return to “Bug Reports”
