Hi I'm having an issue with the Octane node editor and I believe it is a bug with the new version of C4D which was just released.
I cannot use keyboard shortcuts or type when the node editor is the active window it just initiates the shortcut within C4D itself. So I basically cannot delete nodes with delete key or type to find nodes.
Just showing steps me trying to delete a node and search for a node with the context menu, pressing 'O' shows how it just frames the cube even though the node editor is the active window.
INFO
A. Windows 11 (Build 22631)
B. 2x RTX 6000 (ADA)
C. 256GB
D. 572.83
E. OctaneRender 2024.1.2
F. OctaneRender plugin 2025.2.0
G. C4D 2025.3.0 (latest)
Octane node editor not responding to keyboard when active
C. RAM Capacity (i.e. 6 GB)
- mikeadamwood
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
- ChrisHekman
Cinema4D 2025.3 has a regression we are aware of. We found a temporary workaround and will be releasing a fix from our side soon. Until then, we advice to use C4D 2025.2mikeadamwood wrote: Thu Jun 19, 2025 11:10 am Hi I'm having an issue with the Octane node editor and I believe it is a bug with the new version of C4D which was just released.
INFO
C. 256GB
D. 572.83
