What is the shortcut key for re-rendering? And how can I set this shortcut key in Cinema 4D? I have a large number of pictures to create and need the shortcut key to improve efficiency.
还有这里的帖子我如何添加图片,方便问你们问题
						C4DOC
- anythingdentist
The default shortcut key for re-rendering the current view in Cinema 4D is usually Shift + R. If you want to customize it, go to:
Edit > Preferences > Customize Commands, then search for "Render View" or the specific render command you use. You can assign or change the shortcut there.
To add images to your post here, just click the attachment icon (usually looks like a paperclip or image) below the text box when you're writing your message. You can then upload a screenshot or any picture to help explain your question better.
You want to re-render faster in Cinema 4D and assign a shortcut key for it, because you have many images to generate.
First, by default in Cinema 4D: Render to Picture Viewer shortcut: Shift + R
Render View (viewport only) shortcut: Ctrl + R (Windows) or Cmd + R (Mac)
That's a super helpful tip! I've been doing a lot of test renders lately, and having to manually click through the menus is a bit of a pain. Knowing the default shortcuts, especially **Shift + R for the Picture Viewer**, is a huge time-saver. It's exactly the kind of workflow optimization I'm looking for. Thanks for sharing this!
