OctaneRender® pre-Beta 2.41 (win x64) [OBSOLETE]
abstrax
rotorgames wrote:Tried to load. obj! And Octane immediately hung! I have 2 monitor possible problem with this! Error on the Russian language!
Hmm ok. Do you get to the voxelizing stage or does it die before the voxelizing? Do the demo scenes work?
Cheers,
Marcus
rotorgames
Die at different stages! happens to voxelizing and sometimes after! But now when I use the exporter everything is fine!
yoyoz
Hi Marcus,
I've attached a scene that made 1.23 crash when importing the obj. (that's bad geometry, but Octane shoudn't crash anyway). May be you want to test it against 1.24?
Cheers,
Lionel
bad_geometry.zip
(464.58 KiB) Downloaded 189 times
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
radiance
Hey all,
what we need to determine now is if this release solves the problems with the previous 2.4 released two days ago and if it's good to go, as others are patiently awaiting the builds for the remaining platforms,
Could people test and report regarding the issues that we fixed too ?
Radiance
suhail_spa
thanks!
btw in ver 2.41, the sunlight does pass thru the glass (in pathtracing mode)
attached is scene rendered with pathtracing on ver 2.41
Also, i usually try to save the camera nodes as external files, and then upload them back again in case i need to change camera angles. But everytime (even in previous versions), when i join an imported camera node to the mesh preview render target- the camera angle remains the same (same as previous camera before joining the node)- until i tweak (or change some parameter of) the previous camera which was just disconnected from the node..then the camera angle shows correctly.
I am sure this is just a small bug- and can easily be rectified in future versions.
If this is fixed (i tried it in ver 2.41 also, but didnt work) at least we can quickly skip thru various saved camera angles..
rendered with ver 2.41...sunlight thru glass
DELL Precision M4500 Laptop (win7 -64bit, Intel core i5 M520 2.4Ghz, 4Gb, Quadro FX880 1Gb, PCI express slot)
with GTX 460 -2GB (running on home-made GPU-expander)
radiant
necko77 wrote:plz Octane team implement this simple wish into nodes
Many times as i work i have a lot of materials on my scenes and its terrible to float over every triangel node to see its name
Can you program nodes like when i select material with material picker i want that node to become red or any other color :) you can choose
OMG
+1
I was just thinking of that like yesterday, the totally same thing
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
Elvissuperstar007
suhail_spa wrote:thanks!
you have a light passed through the glass?
suhail_spa
yes..in path tracing mode..
check this link too...
http://www.refractivesoftware.com/forum ... f=9&t=4997
it did pass thru glass in ver 2.4 also
maybe what we call this- a blessing in disguise ;)
thank you refractive team.
pixelrush
Vital signs here after change of driver and Octane.
I notice Centre View not working properly in Graph editor or at least with a wide .obj node ie. with many mats.
Dont have much time to test today.
Let you know... ;)
Still some bugs from previous reports -
Loss of colour to white when switching mat type.
'Reflection' label not always showing - 'Specular' instead
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Elvissuperstar007
suhail_spa wrote:yes..in path tracing mode..
you reduce the opacity of the glass? I have only in this case, the light begins to pass, but it's not right!
