OctaneRender® for 3ds max® v2025.1 - 16.04
HHbomb
Hi NZ !
I made a test I got :
I use your file is ok, but when I render with "save all render passes as a single multi layer EXR file" I get :
and when I use new cryptomatte node in Resolve 20 I get : ( no surface, just edges )
The attachment resolve.JPG is no longer available
It is better to use Octane EXR or MAX one ?
HHbomb
note : Attachements don't work as expected ( need to change files names and attachement numbers )
Elvissuperstar007
If I try to add any modifier to an STL file with the Octane renderer selected, it can freeze, and after thinking for a long time, this panel popped up for me
Here is the file in the archive, the ring model is not mine, I was only given the opportunity to render it. Maybe there is something wrong with the STL
win10/ nvidia 4090/ xeon e5 2690 v0 (AVX1) 64GB DDR3 1866 (quad channel) ssd SATA Sumsung EVO/ Game Ready 572.83/ be quiet! Straight Power 11 Platinum 1000W
Jewelry studio New York.rar
(19.35 MiB) Downloaded 117 times
Last edited by Elvissuperstar007 on Wed Apr 09, 2025 11:07 am, edited 2 times in total.
remKa
Hello NeonZorglub,
Not a big issue but I still have the empty tab problem on max 2024 (latest updates), 572.83 Studio Drivers.
3ds Max is freshly installed, it happens every time on new scenes
AMD 9950x3D / RTX 4090 / RTX 3090 / 192 Go DDR5 / Win 11
http://www.remy-kerbiquet.com
mbetke
Are there changes in texture environment 2D transform angles with this version?
I had several old scenes with latest version before 2024.1.2 with a complete different sun angle now.
Usually I use a Texture-Environment with a RGB Image (HDR). I use the UV transform slot and apply an 2D Transformation with a value for example 0,25 and 0,0.
With current version, the 0,25 is now exactly 180° wrong. So to get my old 0,25 I need to enter 0,75.
This happens to all of my scenes. And I use a lot of recent scenes from many years.
PURE3D Visualisierungen
paride4331
Elvissuperstar007 wrote: Tue Apr 08, 2025 11:29 am If I try to add any modifier to an STL file with the Octane renderer selected, it can freeze, and after thinking for a long time, this panel popped up for me
Hi Elvissuperstar007,
I can't reproduce your issue using your scene. From the screenshot, it looks like you're using the retopology modifier. I tried using that as well, but aside from a few freezes that I can resolve with the unfreeze button, I haven't experienced any permanent freezes. This modifier takes some time to update the changes, but I haven't encountered any pop-up windows like you mentioned. Do you have other applications using the GPU and VRAM (like Chrome, for example)?
paride4331
HHbomb wrote: Tue Apr 08, 2025 9:54 am Hi NZ !
Hi HHbomb,
Did you set the 'Rendering Toon Map' option to LDR in the Render Settings panel?
HHbomb
Hi Paride. No it is set to HDR
paride4331
HHbomb wrote: Wed Apr 09, 2025 12:56 pm Hi Paride. No it is set to HDR
Hi HHbomb,
You should use LDR with cryptomatte layers
HHbomb
What about image quality with LDR ?
Return to “Releases”
