Addon version 30.2 preview update issues
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
grimm
I have a very simple scene setup with just the default cube, I have also setup and defined the kernel and added both a world environment and textured the cube. On the "Layout" workspace and hitting F12, the cube renders without issues. If I switch the workspace to "Shading" and turn on the rendered shading the cube will start to render and then stops at 1 SPP, although the render time keeps increasing. If I open the device preference, network preference, or the activation state windows, the preview will update when the window is closed. If I change to another workspace and then come back to the "Shading" workspace the shading reverts back to "Solid Shading" and doesn't remember that I had chosen the rendered shading. Sometimes hitting F12 will render but not show the cube. Thanks,
linograndiotoy
Thank you for reporting this.
We´re aware of the issue, it will be fixed asap.
The solution for now is to turn off the preview before starting the render.
Return to “Bug Reports”
