OctaneRender™ for Blender 2025.1.Beta.2 - 30.1 Cut Paste Bug
In the shader editor, copy and paste works fine however when I cut object and paste, It is not pasting what I cut. It is pasting the previous item in memory.
example.
Copy NODE 1. Paste = NODE 1 ok
Then
Cut NODE 2. Paste = NODE 1
not sure if it's a Blender or Octane issue.
- linograndiotoy
I´ll test this in both custom and regular version. Thanks!
- linograndiotoy
There's no "cut" option in the Shader Editor. This means that the shortcut you´re using to "Cut" nodes is basically doing nothing, so what has been "copied" by a previous "Copy" operation is correctly pasted.
Ctrl+x in the Shader editor is just deleting the nodes.
So, not an issue.
So, not an issue.
