Copernicus op syntax not working in Solaris
Hydra Solaris
Andreu
It seems that the op:/pathtocops syntax is not working in Solaris. Is this on the road map to be implemented at some point?
BK
Hi Andreu,
Thank you so much for the finding.
Would you please share a sample scene to attach to our internal ticket?
We will investigate if we can implement the op:/pathtocops syntax for Octane Solaris!!
cheers
Kind Regards
bk3d
Andreu
Hi BK,
Thanks for taking a look at it.
I have attached 2 files with a simple example of the Object level setup and the Solaris.
OpSyntaxExamples.zip
2 separate hiplc files with examples of OP syntax
(145.05 KiB) Downloaded 864 times
galleon27
BK wrote:Hi Andreu,
cheers
Seriously?????? This has already been reported a while ago by me and i provided the files needed and explained everything
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
BK
Andreu wrote:Hi BK,
Thank you so much for the files.
The Op sytax seems to work only with Karma maybe I am doing something wrong!
We are discussing reaching out to Sidefx to help implement this feature.
Hope will get resolved asap!
Cheers
Kind Regards
bk3d
BK
galleon27 wrote:
BK wrote:Hi Andreu,
cheers
Hi galleon27,
Apology for the delays.
We still remember and for some reason, the task was pushed for later.
Cheers
Kind Regards
bk3d
Andreu
Thanks for the update BK.
Hopefully it gets solved, is quite an important feature since Solaris is clearly the future imo.
Terryvfx
+1 for Copernicus in Octane.
Return to “Hydra Solaris”
