Otoy Octane Black Friday 2024 bundle deal?
Correction, Black Friday offer ends tomorrow Dec 5th at 5PM PST.
ciao,
Beppe
Rik
Just purchased the BF deal of a year's subscription.
Buried somewhere in the Otoy/Octane pages I read that for existing subscriptions (I had 6 months left) subscribers should contact support to not lose their current remaining subscription and have it added to the newly purchase BF deal. Can you give me the email for the support staff who can sort this please.
Shortly after purchasing the BF deal I received 2 emails.
First one was "Thanks for signing up for an OctaneRender® Studio+ (Yearly) subscription!"
Second was "Your OctaneRender® Studio+ (Yearly) Subscription cancellation has been processed. You will no longer be periodically charged for this service."
When I view the page with my subscriptions I can only see the my current subscription which says it expires in 6 months.
Any idea why it's not also showing the new BF deal subscription?
Rik wrote:Just purchased the BF deal of a year's subscription.
Please write to help at otoy dot com sharing your OTOY username, thanks.
ciao,
Beppe
Timmaigh!
So did you write to the helpdesk to find out, whether everything is as it should be? I got the BF deal as well and got those 2 e-mails. My subscription would otherwise end on 20th March next year. But i believe i saw somewhere in the process of paying for it, the new subscription (one we paid for it now) will only kick once the old one runs out, and until then it would show only the old one. The cancellation e-mail, i thought, meant because i got the BF deal, the subscription wont try to automatically renew on that 20th March and charge me money for another year, which it would do otherwise. Maybe i am wrong though. Guess i might want to write to support myself.
On topic of Greyscale Gorilla, thats a nice bonus, but is it anyway to use it with 3Dsmax? I can see, when i want some specific material off their library, it downloads its textures to harddrive, so i can technically set-up the material myself using them. But i am not particularly knowledgeable in this regard - say i downloaded the suede material, have all its PBR textures... how do i know which material type to even start up with, i mean diffuse, glossy, universal? And then one of those textures is called SheenOpacity and SheenWeight, where do i put those, if Octane does not have "fields" for them in its material settings?
R9 7950x, 64GB DDR5 6000 MHz, 2x RTX 4090, Samsung 990 Pro 2TB, Kingston KC3000 2TB, Kingston KC3000 1TB, WD Caviar Gold 6TB, Win11 Pro 64bit
Rik
I checked a day or so later and my subscription/license whatever now shows they last till June 2026 so someone must have added them together so happy days!
Here's what they said...
By clicking "View Info" next to the license on the Licenses Subscription page, you will see the actual expiration date.
Kind regards,
Gabriele
Octane Support Team
However, I did also email the helpdesk to check why I only have 2 unlocks left but was told that 2 is now the standard. If you run out you have to contact them to reset them, all the way back to 2 :roll:
Hi guys,
nice to hear you have solved your license issues.
@Timmaigh: start with the new Standard Surface material coming from Arnold Render, it has a Sheen Weight pin.
About Sheen Opacity, maybe you can use it as a mask for a Composite material between two Standard Surface materials with different Sheen settings :roll:
ciao,
Beppe
Timmaigh!
Kind regards,
Gabriele
Octane Support Team
Thank you, i checked the "View Info" and its the place where i remember the read new license will kick in when the old runs out, that i talked about before. So everything shall be fine.
Timmaigh!
bepeg4d wrote:Hi guys,
ciao,
Beppe
Thank you Beppe, will look into it!
The other thing about the opacity map being intended for composite material, maybe thats the case, thats exactly my point, how would i know. And if so, what are the different sheen settings they between those 2 materials. Some kind of system, that would store these informations / material settings inside some additional file, you would import in, alongside those textures, would be very helpful. Like .mat files in 3dsmax or whatever. Or is there anything like that?
One workaround that comes to mind is to install blender, connect it to GreyscaleGorilla, open the material there and then export as orbx...that should work, right? But i guess i need Octane plugin for Blender to have installed, do i have access to multiple plugins as part of license, or only single one i chose (3dsmax), when i subscribed?
I think you need to use one material without sheen, and the other one with all sheen settings.
About plugins, we ask to choose a plugin just to know how many users there are per plugin type, but you can download and install any OctaneRender DCC plugin you want to use.
ciao,
Beppe
rodrigokuo
Are we having a BF bundle for this year too?
