OctaneRender 2024.1 for Houdini production (2024.1.0.1)
- lavrenovlad
Universal light behaves weird in this version too. I put intensity value of 20 000 it seems normal after IPR reload, then if I touch the slider again slightly it becomes overexposed until I reload IPR again and some other bugs, may be related to IPR not updating something properly and not related to the universal light itself
- ricky_otoy
Thanks for the reports, ok so yeah we did fix an issue after ROP export then closing IPR now. I hope this is tied to your ROP render exit crash issue. (fingers-crossed!)
Also, the over-bright jumps on with the light while adjusting was fixed for the next build too. (I assume it is the same issue you are talking about)
- lavrenovlad
Tbh I think it might be IPR updating issue, since lights are materials and they just don't update correctly.
BTW don't forget about the issue with the IPR that is still around, when opening a project and choosing a ROP in ROPs menu straight away in the IPR causes an error. Need to start the IPR first by clicking the "play" icon and then I can choose from the list of ROPs and can switch between them without an error.
- ricky_otoy
It has been logged, I can't say if we will fix that check for the coming build or not but will get sortedlavrenovlad wrote: BTW don't forget about the issue with the IPR that is still around, when opening a project and choosing a ROP in ROPs menu straight away in the IPR causes an error. Need to start the IPR first by clicking the "play" icon and then I can choose from the list of ROPs and can switch between them without an error.
- lavrenovlad
There is a bug with "Composite Texture" node that has been around for trillion years. Multiple inputs get messed up when I open the file again, need to disconnect and re-arrange them again..
I reported it a while ago
- ricky_otoy
We unfortunately reintroduced this bug recently, we are aware and hopefully will squash it soon!
- lavrenovlad
Any plans in the near future to add auto IPR refresh when new models added for example? It works pretty well in Redshift and Renderman
- ricky_otoy
Some IPR update 'updates' will be in the next build, including update on adding new item.lavrenovlad wrote:Any plans in the near future to add auto IPR refresh when new models added for example? It works pretty well in Redshift and Renderman
