OBJ Export Settings for Octane
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
thwak
WiKKiDWidgets wrote:
thwak wrote:Is this correct for 2.49?
I also poke the HQ button.
OK. That must be the 'High Quality No' button in Radiance's 2.5 screenshot above then.
So this one is right then:
Ubuntu 9.10 x64 | GTS 240 | 260.19.44 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb| Blender 2.56a/latest Yoyoz plugin
WinXP32 | GTS 240 | 266.58 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb | Blender 2.56a/latest Yoyoz plugin
WiKKiDWidgets
'Zactly!
Other little notes:
Do not use spaces in your Texture names. Otherwise Octane won't pick them up. (They will show up as base material)
Do not use Unicode characters in Texture or Material names. Causes crashes.
Apply Scale and Rotation (Ctrl-A) prior to exporting large scenes. The .OBJ function 'Apply Modifiers' I think is supposed to handle this, but I have found that not doing it causes crashes.
Remove Doubles. If you import a mesh into your scene, make sure to Remove Duplicate Verticies. (Edit mode: W+Remove Doubles) Alhough I have had many Meshes work fine with doing this, I have found that to be the cause of import failures sever times. (Ususally when there aare allot of them.)
Thats all I can think of right now. Haven't had coffee yet. *yawns* :geek:
Vista 32 (<--EEEW!)| Intel Quad Q6600 2.4Ghz | 4Gb ram | Dual NVidia GTS 250 1Gb (Non-SLi)
thwak
Handy list! Thanks.
pixelrush
dont use .obj file name with spaces either as Octane wont find the mtl.
all materials will default to blue 0,0,1
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Cire
Isn't Triangulate supposed to be enabled as well?
Win XP-64 & Ubuntu 9.10-64 | GeForce GTX 285 | Quad 4GHz | 8GB
James
Octane converts to tris on import anyway, so it makes no difference really.
Kubuntu 9.04 | Nvidia Gainward 9500 GT | Intel Core2 Quad 2.40 Ghz | 4 GB RAM
havensole
The edge issue can be easily solved by using the clean mesh script. I also find that making sure to recalculate the normals helps prevent meshes from not loading properly. I haven't tried any of this in blender 2.5 yet, just 2.49 and 2.48.
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
mlody47
Softimage | XSI 7.0 to *.OBJ
I dont know if someone here is using xsi :)
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
James
Thanks Mlody47!
thwak
Do the 2.49 settings not warrant posting? Still a lot of folks on here using it.
Return to “Resources and Sharing”
