Setting Curves
Elvissuperstar007
Is it possible in the future to add a variant with a curved setting to the material?
john_otoy
Hi Elvissuperstar007,
Have you tried the "Apply custom curve" texture layer in 2024.1?
custom_curve_001.ocs
(27.48 KiB) Downloaded 120 times
Elvissuperstar007
Yes, in any version in the future, the main thing is to add a curve, it’s much more convenient for control (2025-2026 ....
You just need to make a tick or curve or slider in the preference settings!, so as not to overload the interface, people themselves will choose the most convenient option
the curve will also be convenient for composition layers, this is a more common method
I'm not asking you to finish it now, but it would be nice to add this feature to Octane 2025.+
Elvissuperstar007
Is it possible to create a function directly in the texture? now it looks kind of complicated
if you make complex materials, this node system will be overloaded with curve nodes, and if you need to separately adjust the curve for each texture?
