Mesh uv projection uv set limited to 3 uv set
Sub forum for feature requests etc
PromotsAdmin
currently, the mesh uv projection node is limited to only 3 uv sets.
Can we have the option to set more then 3 uv sets in the mesh uv projection node?
if infinite number is too much then any 2 digit number will be a good start :-)
Thanks.
PromotsAdmin/
paride4331
Hi PromotsAdmin,
This issue is not related to the Octane 3ds Max plugin but to the SDK.
Therefore, you should refer to the general sections.
Return to “User Requests”
