wParallax products
HHbomb
Is there anybody who use wParallax scenes with octane ?
Where can I find jiWindowBox_max_octane_v1_4.osl ? It seems to lack in the demo files ??
Thanks ! :-)
paride4331
Hi HHbomb,
I hope it helps.
OSL_Shaders.rar
(5 KiB) Downloaded 201 times
HHbomb
Hi, Thank you Paride ! I'll keep this at a safe place ! :-)
Now a question : why we can't rotate the planes, how to make something else than a flat facade ?
I can rotate the camera around the planes but I can't rotate the planes with the osl applied, the texture don't work...
Anybody ? Thanks.
HHbomb
Nobody ?
SSmolak
In Cinema 4D version rotating polygon planes doesn't work too but rotating object plane ( using object mode ) works fine. There is limitation in OSL code which use plane object axis instead of polygon normal direction.
HHbomb
Thanks SSmolak .
But for me ( in max ) I tried everything but nothing work. Can't rotate the plane...
HHbomb
Nobody ????
SSmolak
I'm one of the person which made wParallax OSL script for Cinema 4D and I was very close with person who made script for 3dsMax. We made some features for Cinema 4D and Max. As I know you shouldn't any problems if you use it right.
Please be sure that you use latest OSL script. In Cinema 4D there is problem when parallax is rotated in polygon. You should use individual objects per interiors - not polygons.
Can you record video with visible settings ?
SSmolak
Yes you have right, thank you for report that ! This OSL code stopped to work after last Octane updates. Rotating object cause that OSL code doesn't have right object world axis. I reported that issue here viewtopic.php?f=24&t=83348&p=434129#p434129
HHbomb
Thanks SSmolak !!!!
There is a long time I need to use this but nobody can’t tell me why it is not working !!!!
It would be great !!!! Thanks again !!!
Return to “Autodesk 3Ds Max”
