VDB sequence offset for octane
- rustyippolito
I am trying to offset the timing of a cached VDB sequence and i was wondering if there is a way to offset the frames as they come in via the Geometry Node's Octane/OpenVDB parameters panel. It would be so nice to be able to access the output of a retime node but i am just looking for a way to not have to have duplicate cache sequence that i have to manually rename or re-output a whole other vdb sequence after a retime node. Any help would be fantastic:)
- ricky_otoy
Hi there, can you please give me more info on this. Does the normal Houdini retiming not work for you?
