Node type 33 is either unknown, a linker or incompatible to static pin 'groundColor' (P_GROUND_COLOR, type PT_FLOAT) of node 'Environment' (NT_ENV_DAYLIGHT, 000002026E706360)
Tried to access null node pin
Node type 33 is either unknown, a linker or incompatible to static pin 'toonShadowAmbient' (P_TOON_SHADOW_AMBIENT, type PT_FLOAT) of node 'OCTANE_BLENDER_KERNEL_NODE' (NT_KERN_PATHTRACING, 000002021D678930)
Can't read float from static pin 'shutterAlignment' (P_SHUTTER_ALIGNMENT, type PT_ENUM) of node 'OCTANE_BLENDER_ANIMATION_SETTING_NODE' (NT_ANIMATION_SETTINGS, 000002021D6784B0)
tried to send change event for null item or empty pin array
CUDA error (101) on device 0: invalid device ordinal
-> failed to register D3D11 texture
device 0: shared surface output failed
Win 11
RTX 4080 + RTX 2070 SUPER
Octane Blender 27.17
Nvidia Fresh install 537.42 (Studio)
