Rendering in Poser Plugin vs Exporting to Stand Alone?
Petec
From what I understand there are some lighting features in the current version of Octane stand alone that isn't in the Poser Plugin, specifically a lighting method that clears up a ton faster.
With that in mind, is exporting a Poser scene to render in Octane stand alone worth the trouble if one were looking to lower render times for animations?
Also, are there any other pros/cons to exporting from Poser to Octane stand alone?
Is it a huge pain in the butt to export animations?
Will I need to redo materials or cameras or other settings?
If I need to make changes on the Poser side will I need to start the export process all over again?
spartan00j
Petec wrote:From what I understand there are some lighting features in the current version of Octane stand alone that isn't in the Poser Plugin, specifically a lighting method that clears up a ton faster.
Yes, Rendering in the Standalone will be way faster than through the plug-in.
In my opinion, Rendering in the standalone is more fluent, and better than in the plug-in. Since it's node base UI mostly. I'm able to work faster in the stand alone when tweaking materials, lighting Etc..
It's not a huge pain to export the animation. It's seamless. You will not need to redo materials or cameras or other setting.
You will not need to redo materials or cameras or other setting. You will see everything in the stand alone as if you see it in the plugin.
If you need to make changes with the materials you can make them in the standalone. But If you need to make changes to a model animation. There's a trick to not exporting the entire scene all over again. Just make the model that you're changing invisible in octane Standalone. Save it. Then imposer make your changes to the model. Then re-export to the standalone. But here's the thing. Make everything else invisible. So you're just exporting that one models animation that needs to be changed. Then open up octane standalone. Import the new octane file you just created into your old one. And use a group geometry node to merge the two exported scenes together.
furthermore, using the Standalone has opened up other possibilities for animating. I have developed a pipeline with other animation applications because of octane. I'm able to use the ABC/alembic animated geometry file that the export to Octane standalone produces. And import that file into other applications. Like Houdini or RealFlow further expand my animation quality.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
Petec
Thanks for the info Spartan I appreciate it!
Petec
Thanks a bunch!
skientia wrote:All the Octane pages on the website are rendered solely via Standalone.
Universal principles are the benefits, one of which is that rendering outside of a "host" (via a Standalone application which is rare for renderers, or headless or a "deferred-workflow software" such as Foundry Katana) will always be more efficient due to the nature a plug-in implementation and the inconvenience it comes with (data transfer, API limitations and hindrances, and so forth).
There are ways to boost efficiency in Octane Standalone, such as this drag-n-drop approach with presets and "promoted" parameters as shown here (free download early ORBX files).
This Octane Standalone page is being re-written, sections have been added as a sneak-peek to what's coming, in the meantime feel free to consult the older version: skientia.co/cgi/octane-standalone-petec before its supression.
Return to “Poser”
