Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
dasmodular
[/quote]
Can I see a full screen capture of your C4D?[/quote]
dasmodular wrote:
Can I see a full screen capture of your C4D?[/quote][/quote]
I hope this OPTION is ENABLED on your side?
dasmodular
aoktar wrote:
[/quote]
I hope this OPTION is ENABLED on your side?[/quote]
Yes, it is! And it does work as long as there is no hierarchy involved. I think that is the problem, the hierarchy solo doesn't work...
Kind regards,
Denis
Kind regards,
Denis[/quote]
Can't understand well! You should see in LV what you see in the viewport if you enabled this option, confirmed?
dasmodular
Yes it works, except for the hierarchy solo.
I didn't touch the "use viewport solo" setting, it is activated.
SSmolak
Volume Mesher material completely doesn't update :
EDIT : it update only with Oct Obj tag and force update on
vol_oct.zip
(773.49 KiB) Downloaded 127 times
muyu
Hello, is c4d2024.2.0 window11 not supported in 2023.1.2-R7? Not shown in the plug-ins directory.
Anlv
muyu wrote:Hello, is 2023.1.2-R7 window11 not supported in c4d2024.2.0? Not shown in the plug-ins directory.
Yes, you need C4D 2024.3.2
3D Motion Graphics Designer / E-commerce Designer
13700K / 64GB / 4090 / PSU 1250W
SSmolak
There is still issue with camera tag Exposure while changing OCIO view or look. Exposure in Live Viewer is resetting to default 1 until next LV refresh trigger.
ocio_LV_exp.zip
(568.57 KiB) Downloaded 125 times
vesta
is there a reason for what the R7 is not showing in C4d 2024.2 ? thanks
Return to “Releases”
