Cinema4D version 2023.1.2-[R7] (Obsolete stable) 27.03.2024
SSmolak
It looks like C4D Octane version has missing "Border thickness (voxels)" SDF feature in Octane Object tag. Please see here :
viewtopic.php?p=425019#p425019
viewtopic.php?f=24&t=82820&p=432270#p432262
EDIT : works fine using voxel size and transform node. But can be unstable sometimes.
freeter_e
Octane 2023.1.2-[R6]
C4D 2024.2.0
Where can I find the color changes for the "Composite texture layer", now the colors are too bright and make it hard for me to read the text.
freeter_e wrote:Octane 2023.1.2-[R6]
C4D 2024.2.0
It's missing for the node, I'll fix it for next
R7 build is out with some fixes/improvements. Enjoy it!
viewtopic.php?f=85&t=82847
Aleksei
Can't extract archive in Windows 11 23H2.
The problem is in one file, which doesn't have some description.
Trying to 2 variants:
1) Extracting archive via context menu as usual (right mouse button). In this case I get this message and the archive is not extracted:
trying to unzip file via context menu
2) If I enter inside the archive like in a folder and copy the "c4doctane", and then trying to paste this folder somewhere outside of the archive I get the following message (screenshot below). In this case the full archive is extracted except the specified octane.dll file:
trying to copy c4doctane folder from archive
Any other archives on this PC are extracted as expected.
Please, advice what to do.
RTX 4090 | Ryzen 9 7950X3D | 64GB | Win 11 23H2
frankmci
aoktar wrote:R7 build is out with some fixes/improvements. Enjoy it!
Thanks for the requested Texture Manager features, Ahmet. Much appreciated! This will make cleanup/optimization a lot easier.
jayroth2020
Regarding issues with archive extraction and Win11, try using 7zip.
desire
Had no errors with R7, but in result of any extraction method there is "no plugin detected" when cinema 4d started.
Removed R7, put R6 and plugin works.
SSmolak
R7 works fine for me
desire wrote:Had no errors with R7, but in result of any extraction method there is "no plugin detected" when cinema 4d started.
You may see that need 2024.3.2 when you read requirements
Return to “Releases”
