How to remove these creases
spartan00j
Is there any way or settings that I can use to smoothen out these creases? I have a flat plane with a lot of polygons. Most likely 5,000. That is a figure with eight bones. I tried to edit the sub-division to five. But no go(See attached and disregard the magnet effect on the tip).
Is there a setting I can use to smooth the surface out?
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
I would suggest rendering out the Normals render passes, so that you can check that the normals on the mesh are not somehow messed up. In general issues like this a caused by incorrect normals in the mesh.
spartan00j
face_off wrote:I would suggest rendering out the Normals render passes, so that you can check that the normals on the mesh are not somehow messed up. In general issues like this a caused by incorrect normals in the mesh.
okay Thanks
Win 11
128GB RAM
RTX 3060 TI
Return to “Poser”
