Current state of affairs
rexenor86
Hello Octane team and community!
I get the feeling that C4D users are privileged compare to Max users as they have access to more robust features. For example, in Max we only have the option to use a specular material on a mesh to create volume fog (apart from adding scattering to the Daylight system) whereas C4D users can use a versatile Fog Volume Object, or even a null material. Moreover, they have access to a versatile render window which offers render history as well as a render comparison feature a la V-Ray Frame Buffer. There may be other differences that I haven't discovered yet, but you get the idea.
It is clear to me that the majority of your customer base (for the plugin) is C4D users, but I can imagine that Max users should only come second to that. I don't know whether development for Max is hindered by the fact that Max is ancient, thus leading Octane for Max to a dead end..So, questions are:
1. Will you bring these, plus new features to Max any time soon ?
2. Will C4D always benefit from the better version of Octane ?
Thank you!
paride4331
Hi rexenor86,
All plugins use the same SDK, so there are no plugins more or less implemented than others. The difference in some features depends on the plugin developers and the characteristics of the 3D programs that will host the Octane plugin. Each plugin, therefore, has something that another plugin does not have, and vice versa. Specifically regarding your request about volumes, in Octane for 3dsMax you can use .vdb (of course), but also any geometry or .osl. At the moment, the Octane for 3dsMax manual is not updated, but Otoy is working on updating it.
Regarding other features such as the render comparison tool in the live view, it remains to be seen if it can be implemented with 3dsMax. Octane Render does not have this function natively; in fact, it is not available in Standalone. However, the image comparator is available in 3dsMax by loading the desired images.
viewtopic.php?f=27&t=81392&p=422758&hil ... me#p422758
viewtopic.php?f=27&t=78552&p=415620&hil ... me#p415620
https://docs.otoy.com/3DSMaxH/3DSMaxPluginManual.htm
rexenor86
Hi @paride4331,
Thank you for getting back to me, I really appreciate it.
May I ask, why my skinned character (who is supposed to run) appears to be static while rendering an animation sequence ? Is it posible to render animated deforming meshes (such as animated characters) with Octane ? :shock:
Rex
paride4331
Return to “Autodesk 3Ds Max”
