Cant render out frame range
Houdini Integrated Plugin
fl4mingo
Hello,
I have been trying to render out a frame range of my FLIP sims white water and every time I try it gives me a black file.
I have the file split up to have the wave geo as one layer and the WW as its own, the wave geo worked perfectly fine when I rendered out it as a frame range.
It works normally when I view it in the IPR and if I do it as an individual frame so I don't think its an issue with my OCIO config.
So far I have tried:
- Deleting the Octane ROP
- Copying everything to a new file
- Disabling motion blur
- Disabling denoising
Any help would be appreciated!
galleon27
You probably don't have any geometry in the first frame. Try rendering when there's already something in the shot or add a single point and merge it with the geometry.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
fl4mingo
that did the trick thank you! I guess it was only emitting the particles on frame 2 so moving the range over one fixed it.
Return to “Houdini”
