Hi
Feature idea/request:
The ability to project a texture through a light source - but control the shadow sharpness separately from the projected texture. I know this is not physically correct, but this would enable many uses - one of them being the ability to project sharp caustics on underwater environments while keeping the shadows soft and diffuse. In other engines I have seen this implemented as a button that can be switched on/off - or supported through 3ds max legacy light sources with the option to select an engine-specific shadows type. I have no idea how complicated such as feature is to add to Octane Render but I think it would be a really useful addition.
I'm on the demo version of Octane Render for 3ds max.
Best regards,
Henrik
Feature idea: Sharp light projection and soft shadows
Thanks! Convenient on/off button for light use.HenrikBC wrote:Hi
The ability to project a texture through a light source - but control the shadow sharpness separately from the projected texture. I know this is not physically correct, but this would enable many uses - one of them being the ability to project sharp caustics on underwater environments while keeping the shadows soft and diffuse. In other engines I have seen this implemented as a button that can be switched on/off - or cuphead supported through 3ds max legacy light sources with the option to select an engine-specific shadows type. I have no idea how complicated such as feature is to add to Octane Render but I think it would be a really useful addition.
Best regards,
Henrik
- tunnelvoracious
This is also one of the things that I am wondering, do not know who can help?tunnel rush
I think your idea is pretty cool. Hope Octane Render can develop this new feature.HenrikBC wrote:Hi
The ability to project a texture through a light source - but control the shadow sharpness separately from the projected texture geometry dash lite. I know this is not physically correct, but this would enable many uses - one of them being the ability to project sharp caustics on underwater environments while keeping the shadows soft and diffuse. In other engines I have seen this implemented as a button that can be switched on/off - or supported through 3ds max legacy light sources with the option to select an engine-specific shadows type. I have no idea how complicated such as feature is to add to Octane Render but I think it would be a really useful addition.
Best regards,
Henrik
- namdosan1409
I've tested the IES feature with a point light (I've used this kind of ... lights will generate shadows as a point light, casting sharp shadows. car games
