Set Octane Cretendials automatically
hSchoenb
Hi
(Sorry to post in this forum thread, but I do not have the company logion atm.)
Is is possible to set the octane login credentials on some automated way?
We have a renderfarm and a new user for the renderfarm only.
And it would be nice to copy some file, copy registry settings or use env vars to set the credentials.
Is there a way?
hellguy
You may be interested in the "Unattended/Silent Authorization (Online Mode Only)" feature, as noted in the documentation.
You will need to contact [email protected] if you are interested in having this feature enabled for your account.
Another option for authorization is using an unattended authorization token. This allows OctaneRender to activate in online licensing mode without requiring you to enter in a username and password. This works by saving an authorization file downloaded from our SSO system to every machine that runs OctaneRender in a user-agnostic directory. This authorization file can be configured to only be valid for requests from a specific CIDR, preventing this file from being used outside your environment.
If the authorization file does not exist on a machine, you can still run OctaneRender, but you need to enter the username (or login email address) and password.
As this feature has security implications for the licenses in your account, you will need to contact support to request that this feature be enabled for your account. As this feature is an extension of online licensing mode, it requires an active internet connection to function. To request this feature, contact us here.
https://docs.otoy.com/StandaloneH_STA/S ... Access.htm
