Hi, I need help figuring out how to make light objects with octane light tag get color data from the cloner they are in.
For example if you have an area light with an octane tag on it inside a cloner that has a field that applies color to the clones... There seems to be no way to get the color data to the cloned lights.
Is this even possible?
Light objects inside cloners
- jayroth2020
Cinema 4D does not allow lights to be cloned.
- Frez121212
Works with redshift it seems...https://youtu.be/fmyprK9XWeA?si=x0wcB5kWmFnrNCo9
- pixelinfected
cinema4d Allow you to clone lights when you setup a simple clone, if you setup instance clone option the cloner work geometry only.
As you saif that you can clone the lights with cloner and use the light colors via light tag. It's a few click away of tryspixelinfected wrote:cinema4d Allow you to clone lights when you setup a simple clone, if you setup instance clone option the cloner work geometry only.
