There's still an issue with the Gradient node. The sliders get messed up, when you append or link them from another file. I've attached a file to test the problem. The lower slider of the Gradient node in the material "Gradient_Test" is set to 0.5. When you append/link the material into another scene, the lower slider is set to 0. It's not always like that. In another material, the lower slider was set to 0.25 and the higher one to 0.75. After appending the material, the lower slider was set correctly to 0.25, however the upper one was set to 1 instead of 0.75. It's all very erratic.
I'd appreciate if that could be fixed rather soon as it's a crucial thing when you maintain a material asset library and you've got material in there using gradients. As of now, those materials always have to be double checked and corrected after appending. Cheers.
Blender 3.6, Addon version 28.4, Windows 10.
Gradient node append/link issue
C. RAM Capacity (i.e. 6 GB)
- Andreas_Resch
- Octane2023_Scene_ImportCheck_01.zip
- (162.8 KiB) Downloaded 69 times
