Hello guys!
It's not weird that enabling the denoise in the Octane override settings in N panel slows down and even freezes the render? The engine works even better and smoothly without the denoiser! I had a complex scene in the past that I stopped working with cause of this issue which I was not aware of because of the complexity of the scene.. So any answers for this?
Enabling denoise freezes the render!
- Andreas_Resch
This might be related to the problem that I've already reported in the Bug Report section. When the Denoiser is enabled, Blender becomes unresponsive. The viewport isn't updated and I can't even cancel the rendering. However, the rendering is happening in the background. And once the rendering is done, Blender can be used again.
If you want a smooth experience with Octane, never enable denoiser when working on a scene.Hightechmech wrote:Hello guys!
System – Windows 11
System – Windows 11
- Andreas_Resch
I don't. This concerns final rendering.
- Hightechmech
Oh really thanks for mentioning this, I didn't know this is a bug I thought it just happened for me, and you know as I noticed changing the render pass from denoised beauty to beauty (or vise versa) helps the render from stucking in that situation! I really regret that I just abandoned a very complicated sci-fi scene of mine just because of this issue which I couldn't address anymore since the scene had become so heavy and messed up impossible to work with.. and now that I open that scene everything is messed up especially the lighting because the Octane structure seems to be changed fundamentally in the recent updates..Andreas_Resch wrote:This might be related to the problem that I've already reported in the Bug Report section. When the Denoiser is enabled, Blender becomes unresponsive. The viewport isn't updated and I can't even cancel the rendering. However, the rendering is happening in the background. And once the rendering is done, Blender can be used again.
- Hightechmech
That's right.. I figured it out so late unfortunately after missing a lot of projects I intended to do using Octane in Blender.. it seems Octane behaves exactly opposite to Cycles in this special case of denoising!J.C wrote:If you want a smooth experience with Octane, never enable denoiser when working on a scene.Hightechmech wrote:Hello guys!
