Video Texture Broken with Mask in C4D Octane X
azumbrunnen
Hi I'm on 2022.1.1 R6 and I suspect video textures are broken in this build.
Here is how to reproduce:
1. Use a video texture using Octane Image Texture (not c4d image texture and activate animation / calculate frames)
2. Add a mask in opacity channel using Octane Image Texture (set to alpha) and add a uv transform node to it
Playback of the image png sequence stops working. Using universal material.
Any fixes? The viewport and render doesn't update the video texture frame UNLESS i hit refresh and resend the whole scene each time.
Not sure what we are talking exactly, but nothing broken for animated image sequences if you say this. Share a scene with Otoy support if you cannot solve the your problem.
