OctaneRender 2023.1.4 for Houdini beta (2023.1.4.0)
lavrenovlad
Okay, thanks for letting me know!
caseyhupke
Is there an ETA on a non-beta build? VERY interested in migrating.
Renbry
Hello,
Running a Houdini 19.5.769 job on Deadline 10.3
Working great on Windows using this build of Octane Beta
On the Linux boxes I get a consistent error crash showing :
2023-10-28 10:45:32: 0: STDOUT: Ignore Inputs: True
2023-10-28 10:45:32: 0: STDOUT: Output: $HIP/render/Bake/Andata/$OS/$OS.$F5.exr
2023-10-28 10:45:32: 0: STDOUT: Driver: /out/Octane_CGI
2023-10-28 10:45:32: 0: STDOUT: Input File: /mnt/Projects/ElectricLensCo/TinDrum/Sakamoto/Houdini/Sakamoto_Andata_Baking_v04.hip
2023-10-28 10:45:33: 0: STDOUT: Error running event handler:
2023-10-28 10:45:33: 0: STDOUT: Traceback (most recent call last):
2023-10-28 10:45:33: 0: STDOUT: File "Vop/octane_mat_renderTarget, opdef:/Vop/octane_mat_renderTarget?OnLoaded, node /mat/octane_mat_renderTarget1", line 21, in <module>
2023-10-28 10:45:33: 0: STDOUT: ValueError: invalid literal for int() with base 10: ''
2023-10-28 10:45:33: 0: STDOUT: File "Vop/octane_mat_renderTarget, opdef:/Vop/octane_mat_renderTarget?OnLoaded, node /mat/octane_mat_renderTarget_Bake_Volcap", line 21, in <module>
2023-10-28 10:45:33: 0: STDOUT: File "Vop/octane_mat_renderTarget, opdef:/Vop/octane_mat_renderTarget?OnLoaded, node /mat/octane_mat_renderTarget_Bake_CGI", line 21, in <module>
2023-10-28 10:45:33: 0: STDOUT: Error: Caught exception: The attempted operation failed.
2023-10-28 10:45:33: 0: STDOUT: Error loading: /mnt/Projects/ElectricLensCo/TinDrum/Sakamoto/Houdini/Sakamoto_Andata_Baking_v04.hip
2023-10-28 10:45:33: 0: STDOUT: Warning: Bad node type found: octane_vopnet in /mat.
Renbry
I should say that the same .hip file opens, no errors and renders correctly in GUI mode on Linux.
Rendering the .hip from Deadline seems to invoke something that breaks specific to Octane. Of course it's worked in previous 2022 versions so it's a deal breaker at the moment for us to not have the farm working.
Matt Hermans
Electric Lens Co.
PDivision1
Renbry wrote:I should say that the same .hip file opens, no errors and renders correctly in GUI mode on Linux.
Matt Hermans
Electric Lens Co.
Thank you for reporting, I'm looking into it.
BK
Matt Hermans
Electric Lens Co.
Hi Renbry,
Thank you for the post.
Does it crash every scene or only this scene? Is there any script via Hython?
Also, please confirm if you are running the default Houdini. The Py37 version might not work.
Please note the build is still beta and not meant to be used for production.
cheers
Kind Regards
bk3d
PDivision1
Matt Hermans
Electric Lens Co.
I sent you a PM regarding this issue
PDivision1
lavrenovlad wrote:Also the new Composite AOV functionality isn't finished? Couldn't get it to work.
Yes, this will have to wait a bit
timcgi
Is there an eta for a 2023.1.4 beta build for Houdini 20?
PDivision1
timcgi wrote:Is there an eta for a 2023.1.4 beta build for Houdini 20?
We just had a stable release: viewtopic.php?f=102&t=82376 so no beta release is planned.
We are planning to release Houdini 20 support this week.
Return to “Releases”
