OctaneRender® 2023.1 Beta 3
BCres
SSmolak wrote:I noticed problem using Octane Standalone in Windows 11. When more than one Octane windows are opened and we want to close them all, the Octane close splash screen is not visible because it is covered by other windows. We must manually find these small splash windows individually which is time consuming if we had more Octane windows opened before.
These close splash screens should have "always on top" display method enabled like in other typical Windows aplications.
Maybe I'm misunderstanding the issue, but can't you just right click on the icon in the taskbar and select "close all windows"? I just tried it with several instances of Octane open and it closed everything immediately. (see pic)
Close all windows.png (84.5 KiB) Viewed 3265 times
SSmolak
BCres wrote: Maybe I'm misunderstanding the issue, but can't you just right click on the icon in the taskbar and select "close all windows"? I just tried it with several instances of Octane open and it closed everything immediately. (see pic)
Yes this is exactly what I mean but if you change something in scene there is no way to close them all because of floating Octane windows that will pop-up (save changes to current project?). These windows are not on top of main Octane Standalone main windows. Normally they should stay on top.
BCres
Oh, I understand now, SSmolak. Yes, this wouldn't work if you're not getting the dialog boxes on top. Hopefully, they can fix this.
coilbook
Can you please add a virtual thickness to cut outs that were done using procedural noise opacity similar to rounded edges?
In the image you can see rusted metal holes. The holes were done using opacity with noise but they have no thickness. Anyway you can add some slider with adjustable thickness. It's just a thickness that can extend using mesh's normal.
SSmolak
coilbook wrote:Can you please add a virtual thickness to cut outs that were done using procedural noise opacity similar to rounded edges?
Try to add the same noise texture to bump channel with little blur or height option.
john_otoy
OctaneRender 2023.1 Beta 4 has been released: viewtopic.php?f=33&t=82199
Please continue posting bug reports and feedback in the new thread.
