OctaneRender® 2023.1 Beta 3
SSmolak
sethRichardson wrote:Seems like bump mapping in Octane is having some issues.
I think that you have too small "bump height" ( which is not height but some of the semi-blur effect ) amount and try lower bump strength/amount in bump image node.
Generally bumps in Octane have issues because they are too harsh. It cause errors during rendering especially if they are very dense. Octane really needs true gaussian blur option for them.
Bump Height is misleading - this is not height but as I see it mimic blurring by moving bump samples outside of its centre. Bump height is done by bump image strength right ?
coilbook
Why does octane never fix noisy specular reflections and refraction? We were waiting for it for so long!
Can you introduce a light de-nosier just for noise that exceeds a certain threshold?
SSmolak
Perspective projection issue. It create mirrored by U and V axis copy of the same image :
john_otoy
SSmolak wrote:Perspective projection issue. It create mirrored by U and V axis copy of the same image :
Can you provide an ORBX so we can take a look at it? Thanks
SSmolak
john_otoy wrote:Can you provide an ORBX so we can take a look at it? Thanks
Sorry my fault, it was caused because I doing this inside HDRI Environment object and it needs to be clamped by gradient.
coilbook
Otoy,
Have you ever made a complex scene that contains animations, VDBs, particle systems like tyflow, itoo forests, liquids, mesh deform, etc to look for bugs? I noticed we get the most bugs from complex scenes.
I think you should make a scene like this for internal testing.
Hesekiel2517
First of all thank you for alle the great features! Second of all I just want to +1 on the bump and noisy refraction/reflections issues. These two are my main problems at the moment with octane.
All the best
john_otoy
coilbook wrote:Otoy,
Can you provide an ORBX for us to look at? You did not reply the last time I PMed you.
SSmolak
I noticed problem using Octane Standalone in Windows 11. When more than one Octane windows are opened and we want to close them all, the Octane close splash screen is not visible because it is covered by other windows. We must manually find these small splash windows individually which is time consuming if we had more Octane windows opened before.
These close splash screens should have "always on top" display method enabled like in other typical Windows aplications.
john_otoy
SSmolak wrote:I noticed problem using Octane Standalone in Windows 11. When more than one Octane windows are opened and we want to close them all, the Octane close splash screen is not visible because it is covered by other windows. We must manually find these small splash windows individually which is time consuming if we had more Octane windows opened before.
I'm not seeing any obvious differences between windows 10 and 11, but it's not clear exactly what you're doing. I tried both splash screens and the "save changes to current project?" dialogs.
Is this happening after restarting your PC? If so, can you record a video so we can see what you're doing?
