Octane shader to C4D for FBX
tatayoyo
Hi, I would like to know if there is a solution to transform octane textures to C4D or export octane textures to an FBX ?
thxs
tatayoyo
thxs a lot do you how export octane texture to alembic ?
you can change the type of all c4doctane materials to Universal material, then export the scene in .orbx to Standalone, then use the Geometry Export node connected to the Main geometry group:
Define the saving path, and enable the material export, then right click on the node and chose Trigger:
ciao,
Beppe
