New Octane gradient map node issue (27.x)
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
J.C
In latest 27.x releases new Octane gradient map makes blender crash or server crash in almost every attempt to render a scene with an object that uses this node in a material.
I haven't tried 28.x yet.
The example file is in attachment.
When trying to render a simple cube after restarting server/blender it displays an error:
CUDA error (400) on device 0: invalid resource handle
  -> failed to map graphics texture
gradient map node.blend
(13.44 MiB) Downloaded 95 times
System – Windows 11
J.C
I've just discovered the
occurs when "Use Shared surface for viewport" option is enabled in preferences.
System – Windows 11
linograndiotoy
Works fine using both latest 2022 and 2023 integrations here.
Return to “Bug Reports”
