OctaneRender® 2023.1 Beta 3
haze
Hi all,
This is the third beta of 2023.1, and we are expecting the next release to be the first stable 2023.1.
As before, for macOS, we strongly recommend you use at least version 13.3 or preferably newer.
Changes since 2023.1 Beta 2
  • Fixed a case where rays became invalid. If a scene has invalid vertex normals, those tend to propagate all over the place including into the generation of secondary rays. By falling back to the face normals in those cases we work around this problem.
  • Renamed the "Composite texture layer switch" node to "Texture layer switch".
  • Fixed the composite texture layer switch node selection no longer updating after an invalid switch index is selected.
  • Fixed crash during shutdown of the net render node.
  • Fixed film region size being locked to 1024x512 if the region size pin is disconnected. It should now cover the film up to the bottom right corner, which can only be done by maxing out the region size.
  • Fixed output AOVs being composited before info passes are ready.
  • Fixed inconsistency between CUDA and Mac when sampling mix materials with different opacities.
Downloads
Downloads for Studio+ subscription users:
OctaneRender Studio+ 2023.1 Beta 3 Standalone for Windows (installer)
OctaneRender Studio+ 2023.1 Beta 3 Standalone for Windows (ZIP archive)
OctaneRender Studio+ 2023.1 Beta 3 Standalone for Linux
OctaneRender 2023.1 Beta 3 Standalone for macOS
OctaneRender Studio+ 2023.1 Beta 3 Node Windows (installer)
OctaneRender Studio+ 2023.1 Beta 3 Node for Windows (ZIP archive)
OctaneRender Studio+ 2023.1 Beta 3 Node for Linux
Happy rendering
Your OTOY team
coilbook
AI light renders octane lights very well and fast but it has hard time denoising mesh lights and vdb lights like fire. Maybe AI light needs more training with mesh emitters and vdb emitters?
J.C
Hi, thanks for the build! I've been trying to get the light beams in post processing working but I can't get them to work. Could you provide a working example?
edit:
I made it work.
System – Windows 11
J.C
I've came across an issue with quad and disc Analytic light. It produces very short beam when Light beam is enabled. The visible beam is also very noisy.
System – Windows 11
elsksa
J.C wrote: edit:
I made it work.
Could you share how?
I've done all the correct steps and can't get it. Enabled the relevant options, light is rather small, nothing. I'd be surprised if I missed a step somewhere as I triple checked it all.
SSmolak
Transparent ( high thin wall transmission ) materials like glass have visible shadows in AOV shadow pass :
even with disabled shadow visibility in object tag. Only way to get rid of the shadows in shadow pass is to disable "S"un in object light pass mask
J.C
elsksa wrote:
J.C wrote: edit:
I made it work.
Use directional or sun light. Enable "Use in post volume" in light properties. Turn on light beams effect in Post processing volume settings.
fog2023_test3.orbx
(4.88 MiB) Downloaded 117 times
System – Windows 11
coilbook
Does RTX Acceleration work in 2022.1.1 for 3ds max?
Complex scenes without RTX 1 min per frame.
With RTX 1 min 12 seconds. Not sure what's the point of it. All cards are 2090ti and above.
The same problem with denoising . Denoise ON COMPLETION render time is twice longer even though it is on completion.
AI lights problem octane native lights get noise free quick but mesh emitters no difference.
Using the latest nvidia studio drivers
sethRichardson
Seems like bump mapping in Octane is having some issues.
Beta 2 seems to work better.
Here is a example between redshift and octane with a noise bump ran through a triplanar (seems to cause the issue).
Redshift maintains bump detail far far better even at a very small scale.
Octane falls apart and creates weird shading artifacts and loses bump details.
As per usual scaling the scene up from its real world size to the size of a truck seems to work. Except for the fact you break everything else material wise and asset wise thats all based on real world scales.
Please look into this, it seems to be a re-occurring issue within octane.
Last edited by sethRichardson on Fri Sep 15, 2023 8:53 pm, edited 1 time in total.
john_otoy
sethRichardson wrote:Seems like bump mapping in Octane is having some issues.
Please PM me with an ORBX so we can take a look.
