OctaneRender 2022.1.2 for Houdini production (2022.1.2.0)
PDivision1
This is a production release of the OctaneRender™ 2022.1 for Houdini™ plugin compiled with the Octane 2022.1.2 core. This 2022.1.2.0 release is available for the latest Houdini production builds on Windows x64, Linux, and macOS arm64.
Houdini production builds supported by this release: 18.5.759, 19.0.720, 19.5.534, 19.5.569, 19.5.605, and 19.5.640-19.5.682 (using the 19.5.605 build).
New features
To learn more about the new features and improvements of OctaneRender 2022.1.2, please check out the 2022.1.2 release post
Downloads
Release 2022.1.2.0 Studio+ license
Windows Houdini 18.5.759 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.569 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.605 and 19.5.640-19.5.682 - https://render.otoy.com/customerdownloa ... _Win64.zip
Linux Houdini 18.5.759 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.569 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.605 and 19.5.640-19.5.682 - https://render.otoy.com/customerdownloa ... dio%2B.zip
New Linux Houdini 19.5.773- https://render.otoy.com/customerdownloa ... dio%2B.zip
Release 2022.1.2.0 macOS Prime license
MacOS Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... _Prime.zip
MacOS Houdini 19.5.569 - https://render.otoy.com/customerdownloa ... _Prime.zip
MacOS Houdini 19.5.605 and 19.5.640-19.5.682 - https://render.otoy.com/customerdownloa ... _Prime.zip
Release 2022.1.2.0 Demo version
Windows Houdini 18.5.759 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.5.605 and 19.5.640-19.5.682 - https://render.otoy.com/plugindownloads ... _Win64.zip
Linux Houdini 18.5.759 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 19.5.605 and 19.5.640-19.5.682 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Standalone 2022.1.2 version for the network rendering nodes
viewtopic.php?f=24&t=81949
Release Notes
RELEASE 2022.1.2.0
* PLUGIN FEATURES AND FIXES:
- This release only updates octane SDK version to 2022.1.2 (check out the 2022.1.2 release post)
Common Issues and Solutions
- If the plugin doesn't work at all, set HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.
- If you're missing libglut.so.3, install the freeglut package.
Happy rendering,
Your OTOY Team
james_conkle
Thank you for this version! Looking forward to using it :D
Octane C4D Plugin 2021.1 / C4D R25.015
UNIT 0: 2080ti / 6700K / 64GB / 500w
UNIT 1: 2x 3090 / 3970x / 128GB ECC / 1600w
UNIT 2: 5500M / 9980HK / 32GB / 95w
RNDR Artist Calculator
lavrenovlad
This issue is still persistent!
https://www.dropbox.com/scl/fi/s66fr5ht ... 68gch&dl=0
Happens all the time when I use region tool. Happens randomly in almost every scene that is somewhat complex. The error appeared in a scene with only 3GB used vram.
trogers
I've run into that same issue using the region tool many times. It's been at least a year since I first encountered it. I also have to restart Houdini to clear the issue and render again.
Win 11 / AMD 3970x / Nvidia 4090 + 2080 Ti / 128GB
ricky_otoy
lavrenovlad wrote:This issue is still persistent!
Hi lavrenovlad! Can you please DM/PM me a link to the scene you know this happens to. What OS and Houdini build are you using?
lavrenovlad
I reported this issue before, maybe if not to you, then to Juanjo. It doesn't matter what scene you use, you can use any project you want that is somewhat heavy on materials/geometry. Also it happens after working a bit with the IPR, not right away. Win10 btw
galleon27
lavrenovlad wrote:I reported this issue before, maybe if not to you, then to Juanjo. It doesn't matter what scene you use, you can use any project you want that is somewhat heavy on materials/geometry. Also it happens after working a bit with the IPR, not right away. Win10 btw
I can confirm that this issue happens a lot.
Win 10 64bit // GTX 4090 + GTX 3090 // 5900x // 64GB // SideFX Houdini // C4D
galleon27
Curves don't render properly with orthographic camera. Works just fine in Standalone.
curveTest.zip
(104.9 KiB) Downloaded 118 times
ricky_otoy
Hi galleon27, unfortunately, I did not get the same result with your file on 2022.1.2 in Orthographic.
Does it happen to all your curves or just this one in particular?
galleon27
Either scrub the timeline or render to disk and you'll probably get the same result as me.
2023-09-26 14-00-08.mp4
(358.79 KiB) Downloaded 1764 times
Return to “Releases”
