mouseCallback Problems
MB
I would like to use a mouseCallback with a numeric box control. The callback function is listed as a property in PROPS_NUMERIC_BOX, but I can't get it to work.
Infact the only control I can get a mouseCallback to work with is a bitmap. Since I can get it to work with that, I feel I do understand how it should work.
Does the api documentation imply mouseCallbacks work with a bunch of controls that actually don't support this. Code below.
Thanks for your help.
Mark
-- Hookup the callbacks with all the GUI elements
btnFileOpen:updateProperties { callback = guiCallback }
chkDiffuseMaterial:updateProperties { callback = guiCallback }
chkGlossyMaterial:updateProperties { callback = guiCallback }
chkSpecularMaterial:updateProperties { callback = guiCallback }
chkMetallicMaterial:updateProperties { callback = guiCallback }
btnProcessFile:updateProperties { callback = guiCallback }
btnTint:updateProperties { callback = guiCallback }
clsTintColorPicker:updateProperties { callback = guiCallback }
btnTintOk:updateProperties { callback = guiCallback }
btnTintApply:updateProperties { callback = guiCallback }
btnTintCancel:updateProperties { callback = guiCallback }
nbxSpecularRadius:updateProperties { callback = guiCallback }
nbxNormalAmount:updateProperties { callback = guiCallback }
--nbxDisplacementContrast:updateProperties { callback = guiCallback }
--nbxSpecularBrightness:updateProperties { callback = guiCallback }
btnReplacePixel:updateProperties { callback = guiCallback, mouseCallback = mouseCallback }
btnHelp:updateProperties { callback = guiCallback }
btnHelpClose:updateProperties { callback = guiCallback }
btnMainClose:updateProperties { callback = guiCallback }
nbxDisplacementContrast:updateProperties {mouseCallback = mouseCallback }
nbxSpecularBrightness:updateProperties {mouseCallback = mouseCallback }
picDisplacementMap:updateProperties {mouseCallback = mouseCallback }
btnReplacePixel:updateProperties {mouseCallback = mouseCallback }
-- The mouseCallback function, bitmaps work, all others don't
function mouseCallback(component, event)
--print("@mouseCallback", component, event)
if component == nbxDisplacementContrast then
print("@nbxDisplacementContrast mouse events")
if event == octane.gui.eventType.MOUSE_UP or event == octane.gui.eventType.MOUSE_DRAG then
print(" Component, Event =", component, event)
octane.gui.dispatchGuiEvents(400)
setDisplacementMapContrast(nbxDisplacementContrast.value)
end
elseif component == nbxSpecularBrightness then
print("@nbxSpecularBrightness mouse events")
setSpecularMapBrightness(nbxSpecularBrightness.value)
end
elseif component == btnReplacePixel then
print("@btnReplacePixel mouse events")
if event == octane.gui.eventType.MOUSE_DOWN then --or event == octane.gui.eventType.MOUSE_DRAG then
print(" Button Mouse Down")
--Get the pixel color
--setSpecularMapBrightness(nbxSpecularBrightness.value)
end
if event == octane.gui.eventType.MOUSE_UP then --or event == octane.gui.eventType.MOUSE_DRAG then
print(" Button Mouse Up")
end
elseif component == picDisplacementMap then
--print("@picDisplacementMap mouse events")
print(" Mouse Down")
--setDisplacementContrast(nbxDisplacementContrast.value)
end
print(" Mouse Up")
end
end
end
MB
Can someone from Otoy weigh in here?
thanks
jobigoud
I just checked, you're right, only the Bitmap component implements the mouse callback.
MB
Hopefully it will be fixed at some point. Slider controls strike me as the priority.
thx
jobigoud
Can you describe the use case more? Is it for mouse enter/leave? If mouse wheel doesn't trigger a value change I think that's a different problem.
For a bare bitmap control these events are important to add interactivity but on the other controls the interactivity is already built-in.
MB
Simple use case
On a slider, or a numeric box with slider active, I would like to trigger an event that updates the app, in this case the contrast of an image in bitmap, (I have others)
utilizing the new slider value on the slider's non-existent mouse up event. In my case it saves having an apply button on the form, and it avoids too much activity.
if it's attached to a value change event. I tried it with value change, and it stacks all the values in a que and applies the contrast algorithm dozens of times to the image which is not good. If i could flush that stack I could work around it.
I recognize there are numerous controls that it does not make sense to have mouse events, a button for instance.
mouse down)
See below, each image can be manipulated before building an orbx material, but I don't want an apply button for each, just update when releasing a slider.
While I'm on this topic, I would like to be apple to zoom to fit these images into the bitmap control, can I do this, at the moment the user only gets
to see the top left image of the diffuse map they import, and likewise with the others that are generated by the script.
Note the 4 bitmap controls and the 3 slider controls used to tweek the normal, displacement and specular maps.
Return to “Lua Scripting”
