OctaneRender® for 3ds max® v2022.1.1 - 13.21
paride4331
Hi Rik,
Same situation following this link?
https://bridge.octanerender.com/user/
Rik
Erm, not sure. I'm getting some weird error messages.
Can see my account details and subscription but it's not really working. Is this a new thing?
paride4331
Rik wrote:Erm, not sure. I'm getting some weird error messages.
May you try this:
Rik
Same error message unfortunately after I click authorize
User avatar (Default)
merid888
Thank you Paride, i'll test and I'll comment, very kind
coilbook
paride4331 wrote:
coilbook wrote:Hi Paride,
Do you know what ray epsilon value should be for a scene one mile by one mile? It used to be less than 1 not values can go much higher.
Hi coilbook,
Have you solve your issue?
Hi Paride,
I just dont know what the best number should be. It looks good when it is set to 0.5 and looks the same when it is set to 3, for example.
coilbook
Why does octane render phoenix flames way worse than embergen? They are so pixelated. There is no smoothness between vdb cells. One image is embergen the other one is phoenix
paride4331
Hi coilbook,
I don't think I understood, did you export 2 VDBs (one from PhoenixFD and one from Embergeen) and import them into 3dsMax?
coilbook
paride4331 wrote:Hi coilbook,
Hi Paride,
The top image is phoenix simulation with octane volume modifier added. The bottom is embergen vdb. It seems that phoenix never looks smooth and always looks pixelated.
coilbook
For some reason VISIBLE ON SCATTERING doesn't work when you use octane daylight volume. Noisy volume light still shows up.
Return to “Releases”
