After Installing Octane_2022.1.1.1 Axiom won't load
C. RAM Capacity (i.e. 6 GB)
- brandonsavoy
I'm having issues getting both Axiom and Octane to load. If I comment out the 3 lines of code that load Octane in the ENV file it will load. Octane works but it doesn't load axiom if enabled.
This is usually a problem in the houdini.env configuration file. You must define a single environment variable to include all the plugin paths separated by semicolons. The definition of the same variable twice or more doesn't work.
- Gregor.Zimmermann
Hey Juanjo,
would you mind posting a quick example of how to place several paths into the same houdini.env file?
Your help would be much appreciated!
Thank you,
Gregor
Thank you,
Gregor
- ricky_otoy
Hi Gregor,
are you trying to have multiple different octane plugin paths in the same env file? If so, then I am pretty sure that would try load all the plugins and give an API error.
- Gregor.Zimmermann
Hey Ricky,
thank you for getting back to me!
No, I wasn't trying to have multiple version of Octane installed.
Even though it would be a fun experiment having Octane and Octane for Solaris installed simultaneously.
I was more so referring to what the OP asked - if I add the two lines to the Houdini.env, everything works as expected.
However, once I insert another line for a different plugin in there, I get an error.
Could you post an example of what Juanjo was getting at? Like, putting multiple lines in one and use semicolons as divider?
Thank you!
Thank you!
- ricky_otoy
Hi Gregor, I think he meant something like this:Gregor.Zimmermann wrote:Hey Ricky,
Thank you!
HOUDINI_PATH = "C:/path/to/a/plugin1;C:/path/to/a/plugin2;&"
