Octane beta 2.4 intermittent release next week
- Elvissuperstar007
- Contact:
thanks helped
- Elvissuperstar007
- Contact:
Can you make blur function for the static image without using animation?
- cglittenberg
- Contact:
Great News! I think you guys are doing a great job!!!
Dr. Carl Glittenberg
Glittenberg Medical Visualizations
Intel(R) Core(TM)i7 CPU 860 @ 2.80Ghz 2.80Ghz 6,00 GB RAM Windows 7 Home Premium Nvidia GeForce GTX 480
Ok, that should be doable. Next week there will also be a small update in LuxC4D. It will have a non-modal export dialog and support for film offset. I will change the up-vector calculation to hopefully solve that problem. Thanks for the heads up. It's very likely an exporter problem.Elvissuperstar007 wrote:after import in octane, I want to move the camera angles as I like, but the camera starts to pull in the sides .... horizon falls
sorry for my english!
Video Uploading wait!
I want to do the import once, and move the camera without distortion
Cheers,
Marcus
I will have a look at it. I thought, LuxC4D does it already, but I may be wrong here.Elvissuperstar007 wrote:Can you make blur function for the static image without using animation?
Cheers,
Marcus
camera shift, alpha pass and chromatic aberration... wow
good idea to split in two versions so we have something to play with
thanx radiance and marcus for your work
ciao beppe
ciao beppe
Camera motionblur should work with one frame. But all pre23 versions can´t render it.abstrax wrote:I will have a look at it. I thought, LuxC4D does it already, but I may be wrong here.Elvissuperstar007 wrote:Can you make blur function for the static image without using animation?
Cheers,
Marcus
With beta2.2 it works...
face
http://vimeo.com/user2509578
Keep up the good job!
- Elvissuperstar007
- Contact:
Re: Octane beta 2.4 intermittent release next week
Cheers,
Marcus
face
No, I want to blur the statics, no export animation
äh?Elvissuperstar007 wrote: No, I want to blur the statics, no export animation
Without any animation you can´t have any blur...
For a single frame, also a click on the render button, not the render animation button, it works if your scene have an animation.
But it works not with any pre versions, the last worked version is Octane v1.022_beta2.2.
And it worked only with camera animation.
What you want is object motionblur.
That can only work, if you send min 2 frames to Octane, because you need two positions for every vertex. With this two positions, you can calculate the direction of the motion blur.
face
