OctaneRender® for 3ds max® v2022.1.1 - 13.21
coilbook
In case, someone wants to learn about ray epsilon https://youtu.be/oidqVR_3E04
coilbook
Very rare bug. Sometimes octane renders opaque mesh as clear. It's been like this for years. Maybe 3ds max loft or itoo forest have something to do with it.
paride4331
merid888 wrote:Hello, good morning OctaneRender team.
I have a problem when I try to use Ocio config it crash the Octane Vewport Render
Add image like reference
Hi merid888,
Have you correctly configured Aces-OCIO?
viewtopic.php?f=27&t=76951&p=396507&hilit=+aces#p396432
paride4331
coilbook wrote:Hi Paride,
Do you know what ray epsilon value should be for a scene one mile by one mile? It used to be less than 1 not values can go much higher.
Hi coilbook,
Have you solve your issue?
paride4331
coilbook wrote:Very rare bug. Sometimes octane renders opaque mesh as clear. It's been like this for years. Maybe 3ds max loft or itoo forest have something to do with it.
Hi coilbook,
Could you share that?
User avatar (Default)
merid888
God morning from Mérida, Yucatán, México
I been followed the steps just like the link like you post. It's been configurated correct.
I mean, what it is Acescg ? Becouse I read one and over and over again and I put in practice about the tutorial but I can't do a realistic image
Attached reference so you know what I am talking about
paride4331
Hello,
could you share a scene with your OCIO setting?
merid888
Gppd morning Parife
Add file of test with Ocio
Thank you if you can help me.
Excellent weekend
Test Ocio.rar
Test Ocio
(37.62 MiB) Downloaded 130 times
paride4331
merid888,
Your issue is due to the fact that you activated ACES tone mapping without actually setting it up. As you can see in my screenshot, I have deselected that option. Additionally, I changed the type of the sun system and set the sea as an infinite plane.
Test Ocio Parid-2.zip
(37.8 MiB) Downloaded 190 times
Rik
Is something up with the octane live db?
When I import a material there are no texture maps.
Seems to be ones in OTOY-Absolute textures-Brick plus a few others in Absolute textures
Return to “Releases”
