Octane on Laptops
Tugpsx
In an effort to validate the power of portability, I decided to test Octane on a Dell D630 with Windows Vista 4Gb RAM and Quadro NVS135M video card with 128Mb assigned.
radiance
I'm happy it works :)
You're gpu is very small/slow though, i would'nt expect to run anything more complex than your testscene on it...
thanks for reporting though, always interesting to see a new GPU being reported as working :)
Radiance
Tugpsx
Here are a few more tests. Theses are rendered on a Laptop
Included are the settings i used and now the program appears to be more stable.
In Manage 3D settings, Under program settings tab, choose add and select the exe to modify
BTW found that setting the Texture -filtering Quality to Performance worked a lot better. More stable and was even able to open IE and Paint for screen cap and browsing while it was rendering. (may not have been wise, but needed to test it. That's why we have Alpha/Beta)
1) Setup the render environment before loading the model <br />2) Set to this option will allow you to move around quicker when combined with the ALT key
Sam
Hey, welcome to the Octane forums
You see we don't bite :mrgreen:
Thanks for all those tests ;)
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
Tugpsx
Your'e welcome. Running a test with more complex scene. Have to limit materials and apply as needed due to Graphics card.
This will serve as a proof of concept that the program can run on Laptops, while not at best performance but, it will work. 8-)
Thanks for clearing thing up.
gzavye
Thanks to share that :!:
I'll do few more tests on my laptop to see if Octane will run more stable with these tweaks.
win 7 64 | i7 2600 3.4Ghz | 8Go | GTX 580 | 3dsmax | Octane for MAx 3.01 |Driver 306.23 |CUDA Driver 5.00
Tugpsx
Quick test with Sketchup characters.
The Potter gang from sketchup
radiance
Hey,
Pretty great you managed to fit those in your 128MB vram :)
Radiance
Tugpsx
LOL, so true. You guys may want to target the SketchUp community as well, the models transfer and render very well even on a Laptop.
Will try a more complex SketchUp convert and post results.
Robocop ED model transfered from SketchUp 7 rendered on Dell D630 Laptop with Octane Alpha
radiance
The circular shading artifacts are because you're model is very large.
you need to use the unit conversion in the OBJ import preferences panel (file menu),
to configure you're units.
this model is probably kilometers large...
Radiance
