OctaneRender® 2023.1 Alpha 2
john_otoy
coilbook wrote:
elsksa wrote:
coilbook wrote:Why is octane still bad at specular light reflections both with gloss and specular materials even using AI or whatever. Most renderers fixed this problem a long time ago.
How the scene has been setup (lights, materials, etc.) + Kernel settings, please.
it is just AO mode but the scene has 700 scattered streetlights using itoo. Octane has hard time with multiple lights
Can you PM an ORBX to me so we can take a look?
J.C
1. Since the introduction of OCIO there is still an issue when opening file with different OCIO configuration. You can't do anything unless you add new Imager and attach it to Render target. Could automatically disable OCIO in imager when is it not loaded in preferences or different is present?
2. The fog you have introduced is pretty useless as it just dims the image pretending to be a fog. There is no distinction in density between objects in front and far from camera. All have same amount of "fog". I've tried different settings but cant get the same look as with medium. As an example I attach a picture with a medium render and "fog". There is also orbx file to check the issue.
fog5_trick3.orbx
(4.87 MiB) Downloaded 275 times
System – Windows 11
J.C
elsksa wrote: I would presume that it has been intentionally made so to "alert" users about this fundamental (in a working environment) pipeline element that is missing. The Console Log isn't docked anywhere in the GUI by default.
You can alert te users but not block them form working with software when there is mismatch in settings.
System – Windows 11
linograndiotoy
J.C wrote: 2. The fog you have introduced is pretty useless as it just dims the image pretending to be a fog. There is no distinction in density between objects in front and far from camera. All have same amount of "fog". I've tried different settings but cant get the same look as with medium. As an example I attach a picture with a medium render and "fog". There is also orbx file to check the issue.
The attachment fog.png is no longer available
Hey J.C, please consider that the balance between the Fog Strength and the Medium Radius is pretty important.
That's what I was able to get:
I'm pretty sure you can get close to that in your scene as well. The post process fog definitely does well more than "just dims the image pretending to be a fog".
Last edited by linograndiotoy on Wed Jun 07, 2023 6:30 pm, edited 2 times in total.
J.C
Hey J.C, please consider that the balance between the Fog Strength and the Medium Radius is pretty important. That's what I was able to get:
Could you try my scene? I can't get it working to look as with medium or similar to your scene.
System – Windows 11
linograndiotoy
Sure!
linograndiotoy
For some reason to make it work I had to copy/paste your objects in a new scene. Did you export the scene from a DCC?
fog_people_02.orbx
(6.01 MiB) Downloaded 214 times
J.C
linograndiotoy wrote:For some reason to make it work I had to copy/paste your objects in a new scene. Did you export the scene from a DCC?
fog_people_02.orbx
I'll try this, thanks. It was exported from latest Blender build
System – Windows 11
J.C
Got it working after removing object with specular material in front of camera. It somehow interferes with this effect.
There is another issue I've found. The fog is causing non aliased edges on objects in fog:
fog2023_test.orbx
(4.86 MiB) Downloaded 174 times
System – Windows 11
john_otoy
J.C wrote:Got it working after removing object with specular material in front of camera. It somehow interferes with this effect.
Thanks for the scene. It didn't match your screenshot, but I managed to find similar settings to reproduce it.
